ArcGIS.Core.Data Namespace / CodedValueDomain Class / GetCodedValue Method
Name for which a coded value should be returned.
    Gets the coded value that matches the given name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetCodedValue( _
       ByVal name As String _
    ) As Object
    public object GetCodedValue(
       string name
    Parameters
    name
    Return Value
    A coded value for the name. The type of object returned depends on the type of field associated with the domain; for example, if the domain applies to Text fields, the value returned will be a string. If name does not exist in the domain, null is returned.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    The name is often the human readable description of the code.
    Requirements
