Public Function OpenTable( _ ByVal queryDescription As QueryDescription _ ) As Table
public Table OpenTable( QueryDescription queryDescription )
Parameters
- queryDescription
- The QueryDescription object.
| Exception | Description |
| System.ArgumentNullException | queryDescription is null. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A database-related exception has occurred. |
QueryDescription. The first is created by GetQueryDescription(String). Given a table name (fully qualified or unqualified), it encapsulates all the important properties that describe the underlying single table (i.e., QueryDescription.IsQueryLayer returns false). The second flavor is created by GetQueryDescription(String,String). Given a valid SQL SELECT statement and a query layer name, it encapsulates all the important properties that describe the underlying query layer that is created from one or more tables (i.e., QueryDescription.IsQueryLayer returns true). If the table returned is a FeatureClass, the spatial type is taken from the first row returned. To remove ambiguity, QueryDescription.SetShapeType should be called prior to calling this routine.{
await QueuedTask.Run(() =>
DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
AuthenticationMode = AuthenticationMode.DBMS,
Instance = "instance",
Database = "database",
User = "user",
Password = "password"
using (Database database = new Database(databaseConnectionProperties))
QueryDescription queryDescription = database.GetQueryDescription("CUSTOMERS");
using (Table table = database.OpenTable(queryDescription))
//use table
User = "user",
QueryDescription queryDescription = database.GetQueryDescription("SELECT OBJECTID, Shape, FACILITYID FROM EmergencyFacility WHERE JURISDICT = 'Municipal'",
"MunicipalEmergencyFacilities");
// Use the table.
using (Database database = new Database(new SQLiteConnectionPath(new Uri("Path\\To\\Sqlite\\Database\\USA.sqlite"))))
QueryDescription washingtonCitiesQueryDescription = database.GetQueryDescription("select OBJECTID, Shape, CITY_FIPS, CITY_NAME, STATE_FIPS, STATE_CITY, TYPE, CAPITAL from main.cities where STATE_NAME='Washington'",
"WashingtonCities");
using (Table washingtonTable = database.OpenTable(washingtonCitiesQueryDescription))
// Use washingtonTable.
