ArcGIS.Core.Data Namespace / Geodatabase Class / GetDefinitions<T> Method
The type of dataset definition.
Example
    GetDefinitions<T> Method (Geodatabase)
    Gets an IReadOnlyList of specific Definition instances associated with each dataset of type T in the geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public IReadOnlyList<T> GetDefinitions<T>()
    where T: Definition
    Public Function GetDefinitions(Of T As Definition)() As IReadOnlyList(Of T)
    Type Parameters
    T
    Return Value
    A IReadOnlyList of specific Definition instances corresponding to type T.
    Exceptions
    ExceptionDescription
    No valid geodatabase has been opened prior to calling this operation or the DatasetType type is not supported.
    A geodatabase-related exception has occurred.
    Remarks
    Asking for TableDefinition will only return definitions for non-spatial tables (not feature classes), but asking for FeatureClassDefinition will return regular feature classes, as well as annotation and dimensioning feature classes.
    Example
    Obtaining List of Definitions from Geodatabase
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
          IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
          IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
          IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
          bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
          IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
          IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
    Obtaining related Feature Classes from a Relationship Class
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb"))))
          foreach (RelationshipClassDefinition relationshipClassDefinition in relationshipClassDefinitions)
            IReadOnlyList<Definition> definitions = geodatabase.GetRelatedDefinitions(relationshipClassDefinition, DefinitionRelationshipType.DatasetsRelatedThrough);
            foreach (Definition definition in definitions)
              Debug.WriteLine($"Feature class in the RelationshipClass is:{definition.GetName()}");
    Requirements
