ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / CreateMapPoint Method / CreateMapPoint(Double,Double,Double,Double,SpatialReference) Method
X coordinate.
Y coordinate.
Z coordinate. HasZ is set to true.
Measure value. HasM is set to true.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a MapPoint instance with the given X, Y, Z and M coordinates. The HasZ and HasM properties on this instance are set to true.
    Syntax
    public static MapPoint CreateMapPoint(
       double x,
       double y,
       double z,
       double m,
       SpatialReference spatialReference
    Public Overloads Shared Function CreateMapPoint( _
       ByVal x As Double, _
       ByVal y As Double, _
       ByVal z As Double, _
       ByVal m As Double, _
       Optional ByVal spatialReference As SpatialReference _
    ) As MapPoint
    Parameters
    x
    X coordinate.
    y
    Y coordinate.
    z
    m
    spatialReference
    Return Value
    Example
    Builder Properties
      // list of points
      List<MapPoint> pointsForBuilder = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(0, 0, 2, 3, 1),
      MapPointBuilderEx.CreateMapPoint(1, 1, 5, 6),
      MapPointBuilderEx.CreateMapPoint(2, 1, 6),
      MapPointBuilderEx.CreateMapPoint(0, 0)
      // will have attributes because it is created with convenience method
      Polyline polylineWithAttrs = PolylineBuilderEx.CreatePolyline(pointsForBuilder);
      bool hasZ = polylineWithAttrs.HasZ;          // hasZ = true
      bool hasM = polylineWithAttrs.HasM;          // hasM = true
      bool hasID = polylineWithAttrs.HasID;        // hasID = true
      // will not have attributes because it is specified as a parameter
      Polyline polylineWithoutAttrs =
        PolylineBuilderEx.CreatePolyline(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineWithoutAttrs.HasZ;          // hasZ = false
      hasM = polylineWithoutAttrs.HasM;          // hasM = false
      hasID = polylineWithoutAttrs.HasID;        // hasID = false
      Polygon polygonWithAttrs = PolygonBuilderEx.CreatePolygon(pointsForBuilder);
      hasZ = polygonWithAttrs.HasZ;               // hasZ = true
      hasM = polygonWithAttrs.HasM;               // hasM = true
      hasID = polygonWithAttrs.HasID;             // hasID = true
      Polygon polygonWithoutAttrs =
            PolygonBuilderEx.CreatePolygon(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonWithoutAttrs.HasZ;               // hasZ = false
      hasM = polygonWithoutAttrs.HasM;               // hasM = false
      hasID = polygonWithoutAttrs.HasID;             // hasID = false
      PolylineBuilderEx polylineB =
                 new PolylineBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineB.HasZ;                      // hasZ = false
      hasM = polylineB.HasM;                      // hasM = false
      hasID = polylineB.HasID;                    // hasID = false
      // will have attributes because it is passed an attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithAttrs);
      hasZ = polylineB.HasZ;                      // hasZ = true
      hasM = polylineB.HasM;                      // hasM = true
      hasID = polylineB.HasID;                    // hasID = true
      // will not have attributes because it is passed a non-attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithoutAttrs);
      PolygonBuilderEx polygonB = new PolygonBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonB.HasZ;                       // hasZ = false
      hasM = polygonB.HasM;                       // hasM = false
      hasID = polygonB.HasID;                     // hasID = false
      // will have attributes because it is passed an attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithAttrs);
      hasZ = polygonB.HasZ;                       // hasZ = true
      hasM = polygonB.HasM;                       // hasM = true
      hasID = polygonB.HasID;                     // hasID = true
      // will not have attributes because it is passed a non-attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithoutAttrs);
    Construct a MapPoint
      // Use a builder convenience method or use a builder constructor.
      // Create a 2D point without a spatial reference
      MapPoint point2D = MapPointBuilderEx.CreateMapPoint(1, 2);
      SpatialReference sr = point2D.SpatialReference; // sr = null
      bool hasZ = point2D.HasZ;   // hasZ = false
      bool hasM = point2D.HasM;   // hasM = false
      bool hasID = point2D.HasID; // hasID = false
      double x = point2D.X;   // x = 1
      double y = point2D.Y;   // y = 2
      double z = point2D.Z;   // z = 0 default value
      double m = point2D.M;   // m is NaN default value
      double id = point2D.ID; // id = 0 default value
      // Or use a builderEx which doesn't need to run on the MCT.
      MapPointBuilderEx builderEx = new MapPointBuilderEx(1, 2);
      // do something with the builder
      builderEx.Y = 3;
      point2D = builderEx.ToGeometry();
      y = point2D.Y;   // y = 3
      // Create a 2D point with a spatial reference
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(4269);
      point2D = MapPointBuilderEx.CreateMapPoint(1, 2, spatialReference);
      sr = point2D.SpatialReference; // sr != null
      int wkid = sr.Wkid; // wkid = 4269
      // Or use a builder
      builderEx = new MapPointBuilderEx(1, 2, spatialReference);
      // Do something with the builder
      builderEx.SetValues(3, 5);
      x = point2D.X; // x = 3
      y = point2D.Y; // y = 5
      // Change the spatial reference of the builder
      builderEx.SpatialReference = SpatialReferences.WGS84;
      wkid = sr.Wkid; // wkid = 4326
      // Create a 3D point with M
      MapPoint pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4);
      sr = pointZM.SpatialReference; // sr = null
      hasZ = pointZM.HasZ;   // hasZ = true
      hasM = pointZM.HasM;   // hasM = true
      hasID = pointZM.HasID; // hasID = false
      x = pointZM.X;   // x = 1
      y = pointZM.Y;   // y = 2
      z = pointZM.Z;   // z = 3
      m = pointZM.M;   // m = 4
      id = pointZM.ID; // id = 0 default value
      // Create a 3D point with M and a spatial reference
      pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, spatialReference);
      sr = pointZM.SpatialReference; // sr != null
      // Create a point from another point in three ways
      MapPoint clone = pointZM.Clone() as MapPoint; // Has the same values including the spatial reference as pointZM
      MapPoint anotherZM = MapPointBuilderEx.CreateMapPoint(pointZM);  // Has the same values including the spatial reference as pointZM
      builderEx = new MapPointBuilderEx(pointZM); // Has the same values including the spatial reference as pointZM
      builderEx.HasM = false;
      builderEx.ID = 7; // Setting the id also sets HasID = true
      MapPoint pointZId = builderEx.ToGeometry();
      sr = pointZId.SpatialReference; // sr != null
      hasZ = pointZId.HasZ;   // hasZ = true
      hasM = pointZId.HasM;   // hasM = false
      hasID = pointZId.HasID; // hasID = true
      x = pointZId.X;   // x = 1
      y = pointZId.Y;   // y = 2
      z = pointZId.Z;   // z = 3
      m = pointZId.M;   // m is NaN, default value
      id = pointZId.ID; // id = 7
      // Create a point with Z, M, and ID-values
      MapPoint pointZMId = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 5, spatialReference);
      sr = pointZMId.SpatialReference; // sr != null
      hasZ = pointZMId.HasZ;   // hasZ = true
      hasM = pointZMId.HasM;   // hasM = true
      hasID = pointZMId.HasID; // hasID = true
      x = pointZMId.X;   // x = 1
      y = pointZMId.Y;   // y = 2
      z = pointZMId.Z;   // z = 3
      m = pointZMId.M;   // m = 4
      id = pointZMId.ID; // id = 5
      // Pick and choose which attributes to include
      MapPoint point = MapPointBuilderEx.CreateMapPoint(1, 2, false, 3, true, 4, true, 5);
      sr = point.SpatialReference; // sr = null
      hasZ = point.HasZ;   // hasZ = false
      hasM = point.HasM;   // hasM = true
      hasID = point.HasID; // hasID = true
      x = point.X;   // x = 1
      y = point.Y;   // y = 2
      z = point.Z;   // z = 0, default value
      m = point.M;   // m = 4
      id = point.ID; // id = 5
      // Or use a builder
      builderEx = new(1, 2, true, 3, false, 4, true, 5);
      builderEx.ID = 7;
      point = builderEx.ToGeometry();
      sr = point.SpatialReference; // sr != null
      hasZ = point.HasZ;   // hasZ = true
      hasM = point.HasM;   // hasM = false
      m = point.M;   // m is NaN, default value
      id = point.ID; // id = 7
    MapPoint IsEqual
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 5);
      int ID = pt1.ID;           // ID = 5
      bool hasID = pt1.HasID;     // hasID = true
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 0);
      ID = pt2.ID;        // ID = 0
      hasID = pt2.HasID;  // hasID = true
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4);
      ID = pt3.ID;          // ID = 0
      hasID = pt3.HasID;    // hasID = false
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 44);
      ID = pt4.ID;          // ID = 0
      hasID = pt4.HasID;    // hasID = false
      bool hasM = pt4.HasM; // hasM = true
      MapPoint pt5 = MapPointBuilderEx.CreateMapPoint(1, 2, 3);
      ID = pt5.ID;          // ID = 0
      hasID = pt5.HasID;    // hasID = false
      hasM = pt5.HasM;      // hasM = false
      bool isEqual = pt1.IsEqual(pt2);   // isEqual = false, different IDs
      isEqual = pt2.IsEqual(pt3);        // isEqual = false, HasId is different
      isEqual = pt4.IsEqual(pt3);        // isEqual = false, different Ms
      isEqual = pt1.IsEqual(pt5);        // isEqual = false, pt has M, id but pt5 does not.
    Import and Export Geometries to well-known Text
      // create a point with z, m
               100, 200, 300, 400, SpatialReferences.WebMercator);
      // set the flags
      WktExportFlags wktExportFlags = WktExportFlags.WktExportDefaults;
      WktImportFlags wktImportFlags = WktImportFlags.WktImportDefaults;
      // export and import
      string wktString = GeometryEngine.Instance.ExportToWKT(wktExportFlags, point);
      MapPoint importPointGeom = GeometryEngine.Instance.ImportFromWKT(
            wktImportFlags, wktString, SpatialReferences.WebMercator) as MapPoint;
      double x = importPointGeom.X;       // x = 100
      double y = importPointGeom.Y;       // y = 200
      bool hasZ = importPointGeom.HasZ;   // hasZ = true
      double z = importPointGeom.Z;       // z = 300
      bool hasM = importPointGeom.HasM;   // hasM = true
      double m = importPointGeom.M;       // m = 400
      // export without z
      WktExportFlags exportFlagsNoZ = WktExportFlags.WktExportStripZs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoZ, point);
      hasZ = importPointGeom.HasZ;  // hasZ = false
      z = importPointGeom.Z;        // z = 0
      // export without m
      WktExportFlags exportFlagsNoM = WktExportFlags.WktExportStripMs;
      wktString = GeometryEngine.Instance.ExportToWKT(exportFlagsNoM, point);
      hasM = importPointGeom.HasM;  // hasM = false
      m = importPointGeom.M;        // m = Nan
      // export without z, m
        exportFlagsNoZ | exportFlagsNoM, point);
    Import and Export Geometries to EsriShape
      // create an envelope
      List<MapPoint> coordsZM = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(1001, 1002, 1003, 1004),
      MapPointBuilderEx.CreateMapPoint(2001, 2002, Double.NaN, 2004),
      MapPointBuilderEx.CreateMapPoint(3001, -3002, 3003, 3004),
      MapPointBuilderEx.CreateMapPoint(1001, -4002, 4003, 4004)
      Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(
                 coordsZM[0], coordsZM[2], SpatialReferences.WGS84);
      EsriShapeExportFlags exportFlags = EsriShapeExportFlags.EsriShapeExportDefaults;
      EsriShapeImportFlags importFlags = EsriShapeImportFlags.EsriShapeImportDefaults;
      byte[] buffer = GeometryEngine.Instance.ExportToEsriShape(exportFlags, envelope);
      Polygon importedPolygon = GeometryEngine.Instance.ImportFromEsriShape(
                     importFlags, buffer, envelope.SpatialReference) as Polygon;
      Envelope importedEnvelope = importedPolygon.Extent;
      // export without z,m
              EsriShapeExportFlags.EsriShapeExportStripZs |
              EsriShapeExportFlags.EsriShapeExportStripMs, envelope);
              importFlags, buffer, SpatialReferences.WGS84) as Polygon;
      bool hasZ = importedEnvelope.HasZ;      // hasZ = false
      bool hasM = importedEnvelope.HasM;      // hasM = false
      // export with shapeSize
      int bufferSize = GeometryEngine.Instance.GetEsriShapeSize(
      buffer = new byte[bufferSize];
      bufferSize = GeometryEngine.Instance.ExportToEsriShape(
                                   exportFlags, envelope, ref buffer);
      // or use the envelope and envelopeBuilderEx classes
      buffer = envelope.ToEsriShape();
      // buffer represents a polygon as there is not an envelope Esri shape buffer
      // EnvelopeBuilderEx.FromEsriShape takes a polygon Esri shape buffer and returns the extent of the polygon.
      importedEnvelope = EnvelopeBuilderEx.FromEsriShape(buffer);
    MapPoint - GeoCoordinateString Conversion
      SpatialReference sr = SpatialReferences.WGS84;
      SpatialReference sr2 = SpatialReferences.WebMercator;
      // create some points
      MapPoint point0 = MapPointBuilderEx.CreateMapPoint(0, 0, sr);
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(10, 20, sr);
      MapPoint point2 = GeometryEngine.Instance.Project(point1, sr2) as MapPoint;
      MapPoint pointEmpty = MapPointBuilderEx.CreateMapPoint(sr);
      MapPoint pointwithNoSR = MapPointBuilderEx.CreateMapPoint(1, 1);
      MapPoint pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, sr);
      // convert to MGRS
      ToGeoCoordinateParameter mgrsParam =
               new ToGeoCoordinateParameter(GeoCoordinateType.MGRS);
      // 31NAA6602100000
      string geoCoordString = point0.ToGeoCoordinateString(mgrsParam);
      // use the builder to create a new point from the string.
      // Coordinates are the same
      // outPoint.x = 0; outPoint.Y = 0
      MapPoint outPoint =
            MapPointBuilderEx.FromGeoCoordinateString(
                      geoCoordString, sr, GeoCoordinateType.MGRS);
      // 32QPH0460911794
      // outPoint.X = 10; outPoint.Y = 20
      geoCoordString = point1.ToGeoCoordinateString(mgrsParam);
      outPoint = MapPointBuilderEx.FromGeoCoordinateString(
      // z, m are not transformed
      // outPoint.X = 1; outPoint.Y = 2; outPoint.Z = Nan; outPoint.M = Nan;
      geoCoordString = pointZM.ToGeoCoordinateString(mgrsParam);
      // set the number of digits to 2 and convert
      // 32QPH0512
      mgrsParam.NumDigits = 2;
      // convert to UTM
      ToGeoCoordinateParameter utmParam =
           new ToGeoCoordinateParameter(GeoCoordinateType.UTM);
      // 31N 166021 0000000
      geoCoordString = point0.ToGeoCoordinateString(utmParam);
      // 32Q 604609 2211793
      geoCoordString = point1.ToGeoCoordinateString(utmParam);
      // convert to DMS
      ToGeoCoordinateParameter dmsParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DMS);
      // 00 00 00.00N 000 00 00.00E
      geoCoordString = point0.ToGeoCoordinateString(dmsParam);
      // 20 00 00.00N 010 00 00.00E
      geoCoordString = point1.ToGeoCoordinateString(dmsParam);
      // convert to DDM
      ToGeoCoordinateParameter ddmParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DDM);
      // 00 00.0000N 000 00.0000E
      geoCoordString = point0.ToGeoCoordinateString(ddmParam);
      // 20 00.0000N 010 00.0000E
      geoCoordString = point1.ToGeoCoordinateString(ddmParam);
      // convert to DD
      ToGeoCoordinateParameter ddParam =
        new ToGeoCoordinateParameter(GeoCoordinateType.DD);
      // 00.000000N 000.000000E
      geoCoordString = point0.ToGeoCoordinateString(ddParam);
      // 20.000000N 010.000000E
      geoCoordString = point1.ToGeoCoordinateString(ddParam);
    Interpolate M values on a polygon
      List<MapPoint> coords =
        MapPointBuilderEx.CreateMapPoint(0, 0, 0, 0),
        MapPointBuilderEx.CreateMapPoint(0, 1000),
        MapPointBuilderEx.CreateMapPoint(1000, 1000, 10, 50)
      SpatialReference sr = SpatialReferences.WebMercator;
      polygon = PolygonBuilderEx.CreatePolygon(coords, sr);
      // polygon.HasM = true
      // polygon.Points[1].HasM = true
      // polygon.Points[1].M = NaN
      Polygon polygonNoNaNMs = GeometryEngine.Instance.CalculateNonSimpleMs(polygon, 0) as Polygon;
      // polygonNoNaNMs.Points[1].HasM = true
      // polygonNoNaNMs.Points[1].M = 25  (halfway between 0 and 50)
    Find the centroid of geometries
      // simple polygon
      List<Coordinate2D> list2D =
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 2),
        new Coordinate2D(2, 2),
        new Coordinate2D(2, 0),
      polygon = PolygonBuilderEx.CreatePolygon(list2D, SpatialReferences.WGS84);
      // verify it is simple
      bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polygon);
      // find the centroid
      MapPoint centroid = GeometryEngine.Instance.Centroid(polygon);
      // centroid.X = 1
      // centroid.Y = 1
      // map Point
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, SpatialReferences.WGS84);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(5, 2, double.NaN, 7);
      // pt1.HasZ = true
      // pt1.HasM = true
      centroid = GeometryEngine.Instance.Centroid(pt1);
      // centroid.HasZ = true
      // centroid.HasM = true
      // pt1.IsEqual(centroid) = true
      // multipoint
      List<MapPoint> list = [pt1, pt2];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(list);
      // multipoint.HasZ = true
      // multipoint.HasM = true
      centroid = GeometryEngine.Instance.Centroid(multipoint);
      // centroid.X = 3
      // centroid.Y = 2
      // centroid.HasZ = false
      // centroid.HasM = false
    Extend a polyline
      // build a polyline
      polyline = PolylineBuilderEx.CreatePolyline(
        MapPointBuilderEx.CreateMapPoint(1, 1, 10, 20),
        MapPointBuilderEx.CreateMapPoint(0, 0, 10, 20),
        MapPointBuilderEx.CreateMapPoint(1, -1, 10, 20)
      // build the extender line
      var extender = PolylineBuilderEx.CreatePolyline(
        MapPointBuilderEx.CreateMapPoint(2, 2),
        MapPointBuilderEx.CreateMapPoint(2, -2),
      // extend
      var result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes);
      Polyline extendedLine = result as Polyline;
      // result.Parts[0].Points[0] = 2, 2, 10, 20
      // result.parts[0].Points[1] = 1, 1, 10, 20
      // result.Parts[0].Points[2] = 0, 0, 10, 20
      // result.Parts[0].Points[3] = 1, -1, 10, 20
      // result.Parts[0].Points[4] = 2, -2, 10, 20
      // change the flags
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.NoEndAttributes);
      // result.Parts[0].Points[0] = 2, 2, 0
      // result.Parts[0].Points[4] = 2, -2, 0
      // extend
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes | ExtendFlags.NoExtendAtTo);
      // extend with no intersection
        MapPointBuilderEx.CreateMapPoint(1, 1),
        MapPointBuilderEx.CreateMapPoint(3, 1)
        MapPointBuilderEx.CreateMapPoint(1, 4),
        MapPointBuilderEx.CreateMapPoint(3, 4)
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.Default);
      // result = null
      // Use the result ...
    Get line segments corresponding to the normal at the locations where the specified M values occur along the geometry - GetNormalsAtM
      IList<MapPoint> inPoints =
        MapPointBuilderEx.CreateMapPoint(-3000, -2000, 0, 100),
    MapPointBuilderEx.CreateMapPoint(-3000, 0, 0, 200),
    MapPointBuilderEx.CreateMapPoint(-1000, 0, 0, 300),
    MapPointBuilderEx.CreateMapPoint(-1000, 2000, 0, 100),
    MapPointBuilderEx.CreateMapPoint(3000, 2000, 0, 200),
    MapPointBuilderEx.CreateMapPoint(3000, 0, 0, 300),
    MapPointBuilderEx.CreateMapPoint(1000, 0, 0, 100),
    MapPointBuilderEx.CreateMapPoint(1000, -2000, 0, 200),
    MapPointBuilderEx.CreateMapPoint(-3000, -2000, 0, 300)
      polygon = PolygonBuilderEx.CreatePolygon(inPoints);
      polyline = GeometryEngine.Instance.GetNormalsAtM(polygon, 150, 100);
      // polyline.PartCount = 5
      // polyline.PointCount = 10
      // polyline.HasM = false
      ReadOnlyPartCollection parts = polyline.Parts;
      ReadOnlySegmentCollection segments = parts[0];
      LineSegment line = segments[0] as LineSegment;
      // line.StartCoordinate = (-3000, -1000)
      // line.EndCoordinate = (-2900, -1000)
      segments = parts[1];
      // line.StartCoordinate = (-1000, 1500)
      // line.EndCoordinate = (-900, 1500)
      segments = parts[2];
      // line.StartCoordinate = (1000, 2000)
      // line.EndCoordinate = (1000, 1900)
      segments = parts[3];
      // line.StartCoordinate = (1500, 0)
      // line.EndCoordinate = (1500, 100)
      segments = parts[4];
      // line.StartCoordinate = (1000, -1000)
      // line.EndCoordinate = (900, -1000)
    Determine if all the M-values are numbers - IsMSimple
      Coordinate2D[] coords = [new Coordinate2D(-2, 2), new Coordinate2D(3, 5), new Coordinate2D(7, 2)];
      polyline = PolylineBuilderEx.CreatePolyline(coords); // polyline.HasM = false
      bool isMSimple = GeometryEngine.Instance.IsMSimple(polyline); // isMSimple = false
      PolylineBuilderEx polylineBuilder = new(polyline)
        HasM = true
      polyline = polylineBuilder.ToGeometry();
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(-2, 2, -1, 1);
      MapPoint point2 = MapPointBuilderEx.CreateMapPoint(3, 5, -2, 2);
      MapPoint[] points = [point1, point2];
      polyline = PolylineBuilderEx.CreatePolyline(points, AttributeFlags.HasM);
      isMSimple = GeometryEngine.Instance.IsMSimple(polyline); // isMSimple = true
    MovePointAlongLine
      LineSegment line = LineBuilderEx.CreateLineSegment(MapPointBuilderEx.CreateMapPoint(0, 3), MapPointBuilderEx.CreateMapPoint(5.0, 3.0));
      polyline = PolylineBuilderEx.CreatePolyline(line);
      bool simple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
      // ratio = false
      MapPoint pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 0.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 3.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, -1.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 4.0
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 1.0, false, 2.0, SegmentExtensionType.NoExtension);
      // pt = 1.0, 1.0
      // ratio = true
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt = 2.5, 3.0
      // move past the line
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.NoExtension);
      // pt = 5.0, 3.0
      // move past the line with extension at "to" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, 7, false, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt = 7.0, 3.0
      // negative distance with extension at "from" point
      pt = GeometryEngine.Instance.MovePointAlongLine(polyline, -2, false, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // pt = -2.0, 3.0
      // ratio = true
      // pt = 2.5, 3.0
      // line with Z
      List<Coordinate3D> coords3D = [new Coordinate3D(0, 0, 0), new Coordinate3D(1113195, 1118890, 5000)];
      Polyline polylineZ = PolylineBuilderEx.CreatePolyline(coords3D, SpatialReferences.WebMercator);
      // polylineZ.HasZ = true
      // ratio = true, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 556597.5
      // pt.Y = 559445
      // pt.Z = 2500
      // ratio = true, past the line with "to" extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, 1.5, true, 0, SegmentExtensionType.ExtendEmbeddedAtTo);
      // pt.X = 1669792.5
      // pt.Y = 1678335
      // pt.Z = 7500
      // ratio = true, negative distance past the line with no extension, no offset
      pt = GeometryEngine.Instance.MovePointAlongLine(polylineZ, -1.5, true, 0, SegmentExtensionType.NoExtension);
      // pt.X = 0
      // pt.Y = 0
      // pt.Z = -7500
      // polyline with Z but 2d distance = 0
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(5, 5, 0);
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      List<MapPoint> pts = [pt3, pt4];
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      // polyline.HasZ = true
      // polyline.Length3D = 10
      // polyline.Length = 0
      MapPoint result = GeometryEngine.Instance.MovePointAlongLine(polyline, 2, false, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 2
      // polyline with length2d = 0 and length3d = 0
      MapPoint pt5 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      MapPoint pt6 = MapPointBuilderEx.CreateMapPoint(5, 5, 10);
      pts.Clear();
      pts.Add(pt5);
      pts.Add(pt6);
      // polyline.Length3D = 0
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.NoExtension);
      // result = 5, 5, 10
      result = GeometryEngine.Instance.MovePointAlongLine(polyline, 3, true, 0, SegmentExtensionType.ExtendEmbeddedAtFrom);
      // polyline with Z and M
      List<MapPoint> inputPoints =
          MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4),
        MapPointBuilderEx.CreateMapPoint(1, 2, 33, 44),
      Polyline polylineZM = PolylineBuilderEx.CreatePolyline(inputPoints, SpatialReferences.WGS84);
      // polylineZM.HasZ = true
      // polylineZM.HasM = true
      MapPoint pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.5, true, 0, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 18, 24
      // ratio = true with offset
      pointAlong = GeometryEngine.Instance.MovePointAlongLine(polylineZM, 0.2, true, 2.23606797749979, SegmentExtensionType.NoExtension);
      // pointAlong = 1, 2, 9, 12
    Requirements
