ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / CreateMapPoint Method / CreateMapPoint(Coordinate3D,SpatialReference) Method
Specifies the X, Y, and Z coordinates of the MapPoint.
(Optional) The SpatialReference. The default value is null.
    Convenience method to create a MapPoint instance with the given coordinates.
    Syntax
    Public Overloads Shared Function CreateMapPoint( _
       ByVal coordinate3D As Coordinate3D, _
       Optional ByVal spatialReference As SpatialReference _
    ) As MapPoint
    Parameters
    coordinate3D
    spatialReference
    Return Value
    Remarks
    The Z-value is set, and the HasZ property is set to true.
    Requirements
