ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkDefinition Class / GetAssetTypeField Method
    Gets the name of the asset type field. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAssetTypeField() As String
    public string GetAssetTypeField()
    Return Value
    The name of the asset type field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
