ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / GetCanExportRasterTileCache Method
The map to check for raster tile cache content
Example
    Gets whether the map contains one or more raster tile caches that can be exported. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool GetCanExportRasterTileCache(
       Map map
    Public Function GetCanExportRasterTileCache( _
       ByVal map As Map _
    ) As Boolean
    Parameters
    map
    Return Value
    True if the map contains any tiled map or image services
    Exceptions
    ExceptionDescription
    The value of the map parameter cannot be null
    Remarks
    Raster tile caches include tiled map services and image services
    Example
    Export Map Raster Tile Cache Content
      //Does the map have any exportable raster content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportRasterTileCache(map);
      var rasterTileExtent = MapView.Active.Extent;
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportRasterTileCacheScales(map, rasterTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = rasterTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale
          //DestinationFolder = .... (optional)
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportRasterTileCache(map, export_params);
    Requirements
