ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / GetCanExportVectorTileCache Method
The map to check for vector tile cache content
Example
    Gets whether the map contains one or more vector tile caches that can be exported. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool GetCanExportVectorTileCache(
       Map map
    Public Function GetCanExportVectorTileCache( _
       ByVal map As Map _
    ) As Boolean
    Parameters
    map
    Return Value
    True if the map contains any vector tile services
    Exceptions
    ExceptionDescription
    The value of the map parameter cannot be null
    Example
    Export Map Vector Tile Cache Content
      var mapVectorTileExtent = MapView.Active.Extent;
      //Does the map have any exportable vector tile content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale,
          DestinationFolder = @"C:\Data\Offline"
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
    Requirements
