ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / GetCanSynchronizeReplicas Method
The map to check for syncable content
Example
    Gets whether the map contains local syncable content that can be sync'd with its feature service. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool GetCanSynchronizeReplicas(
       Map map
    Public Function GetCanSynchronizeReplicas( _
       ByVal map As Map _
    ) As Boolean
    Parameters
    map
    Return Value
    Exceptions
    ExceptionDescription
    Map cannot be null
    Example
    Check Map Has Local Syncable Content
      //Check map has local syncable content
      var canSyncContent = await QueuedTask.Run(() =>
        GenerateOfflineMap.Instance.GetCanSynchronizeReplicas(map));
      if (canSyncContent)
        //TODO - use status
    Synchronize Replicas for Syncable Content
        var canSyncContent = GenerateOfflineMap.Instance.GetCanSynchronizeReplicas(map);
        if (canSyncContent)
          //Sync Replicas - changes since last sync are pushed to the
          //parent replica. Parent changes are pulled to the client.
          //Unsaved edits are _not_ sync'd.
          GenerateOfflineMap.Instance.SynchronizeReplicas(map);
    Requirements
