ArcGIS.Desktop.Mapping.Offline Namespace / GenerateOfflineMap Class / GetExportVectorTileCacheScales Method
The map containing the vector tile service(s)
The extent controls the range of scales. A larger extent will usually result in a greater number of scale ranges than a smaller extent.
Example
    Get the list of scales to use for determining the level of detail, LOD, to use when exporting a vector tile cache. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public List<double> GetExportVectorTileCacheScales(
       Map map,
       Envelope extent
    Public Function GetExportVectorTileCacheScales( _
       ByVal map As Map, _
       ByVal extent As Envelope _
    ) As List(Of Double)
    Parameters
    map
    extent
    Return Value
    A list of scales or an empty list if there are no exportable vector tile caches
    Exceptions
    ExceptionDescription
    Map cannot be null
    Extent cannot be null or empty
    Map and extent spatial references must be equal
    Remarks
    If there are multiple vector tile services present in the TOC then the returned list of scales is derived from a consolidation of all LODs for the vector tile services (within the specified extent).
    The extent parameter should be the same extent that is used with the ExportTileCacheParams.Extent when exporting the vector tile cache.
    The extent spatial reference must match the spatial reference of the map or an exception will be thrown.
    If the map has no exportable vector tile services then an empty list is returned.
    Example
    Export Map Vector Tile Cache Content
      var mapVectorTileExtent = MapView.Active.Extent;
      //Does the map have any exportable vector tile content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale,
          DestinationFolder = @"C:\Data\Offline"
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
    Requirements
