ArcGIS.Desktop.Mapping.Offline Namespace / GenerateReplicaParams Class / Extent Property
Example
    Extent Property (GenerateReplicaParams)
    Gets and sets the extent of the area to be included in the replica(s).
    Syntax
    public Envelope Extent {get; set;}
    Public Property Extent As Envelope
    Remarks
    The spatial reference of the extent must be the same as the map from which replicas are being generated
    Example
    Generate Replicas for Sync-Enabled Content
      //namespace ArcGIS.Desktop.Mapping.Offline
      var extent = mapView.Extent;
      await QueuedTask.Run(() =>
        //Check map has sync-enabled content that can be taken offline
        var hasSyncEnabledContent = GenerateOfflineMap.Instance.GetCanGenerateReplicas(map);
        if (hasSyncEnabledContent)
          //Generate Replicas and take the content offline
          //sync-enabled content gets copied local into a SQLite DB
          var gen_params = new GenerateReplicaParams()
            Extent = extent, //SR of extent must match map SR
            //DestinationFolder can be left blank, if specified,
            //it must exist. Defaults to project offline maps location
            DestinationFolder = @"C:\Data\Offline"
          //Sync-enabled layer content will be resourced to point to the
          //local replica content.
          GenerateOfflineMap.Instance.GenerateReplicas(map, gen_params);
    Requirements
