ArcGIS.Core.Geometry Namespace / CubicBezierBuilderEx Class / CreateCubicBezierSegment Method / CreateCubicBezierSegment(CubicBezierSegment,SpatialReference) Method
The cubic bezier.
(Optional)The spatial reference. If spatialReference is null, then the spatial reference is inherited from cubicBezier.
Example
    Convenience method to create a new instance of the CubicBezierSegment class from the four control points of a cubic bezier.
    Syntax
    Public Overloads Shared Function CreateCubicBezierSegment( _
       ByVal cubicBezier As CubicBezierSegment, _
       Optional ByVal spatialReference As SpatialReference _
    ) As CubicBezierSegment
    Parameters
    cubicBezier
    The cubic bezier.
    spatialReference
    Exceptions
    ExceptionDescription
    cubicBezier is null.
    Example
    Cubic Bezier Properties
      // retrieve the bezier curve's control points
      CubicBezierSegment cb = CubicBezierBuilderEx.CreateCubicBezierSegment(bezierSegment);
      MapPoint startPt = cb.StartPoint;
      Coordinate2D ctrlPt1 = cb.ControlPoint1;
      Coordinate2D ctrlPt2 = cb.ControlPoint2;
      MapPoint endPt = cb.EndPoint;
      bool isCurve = cb.IsCurve;
      double len = cb.Length;
    Requirements
