ArcGIS.Core.Geometry Namespace / CubicBezierBuilderEx Class / CreateCubicBezierSegment Method / CreateCubicBezierSegment(Coordinate2D,Coordinate2D,Coordinate2D,Coordinate2D,SpatialReference) Method
The start point.
Control point 1 of the cubic bezier.
Control point 2 of the cubic bezier.
The end point.
(Optional) The spatial reference. The default value is null.
Example
    Convenience method to create a new instance of the CubicBezierSegment class from four control points.
    Syntax
    Parameters
    startPoint
    The start point.
    controlPoint1
    controlPoint2
    endPoint
    The end point.
    spatialReference
    Exceptions
    ExceptionDescription
    startPoint or controlPoint1 or controlPoint2 or endPoint is null or empty.
    Example
    Create Bezier Curve Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D pt1 = new Coordinate2D(1, 7.5);
      Coordinate2D pt2 = new Coordinate2D(1.66, 8);
      Coordinate2D pt3 = new Coordinate2D(2.33, 7.1);
      Coordinate2D pt4 = new Coordinate2D(3, 7.5);
      var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
      var bezSeg = bez.ToSegment();
      Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
      //Set symbology, create and add element to layout
      CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
        ColorFactory.Instance.RedRGB, 4.0, SimpleLineStyle.DashDot);
      ElementFactory.Instance.CreateGraphicElement(layout, bezPl, lineSym, "New Bezier");
    Requirements
