ArcGIS.Core.Geometry Namespace / LineBuilderEx Class / CreateLineSegment Method / CreateLineSegment(LineSegment,SpatialReference) Method
The existing line segment.
(Optional) The SpatialReference. The default value is null. If spatialReference is null, then the spatial reference is inherited from segment.
Example
    Convenience method to create a new instance of the LineSegment class.
    Syntax
    public static LineSegment CreateLineSegment(
       LineSegment segment,
       SpatialReference spatialReference
    Public Overloads Shared Function CreateLineSegment( _
       ByVal segment As LineSegment, _
       Optional ByVal spatialReference As SpatialReference _
    ) As LineSegment
    Parameters
    segment
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    segment is null.
    Remarks
    The new instance will be a copy of the input LineSegment instance.
    Example
    Construct a LineSegment using two MapPoints
      // Use a builderEx convenience method or use a builderEx constructor.
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      // BuilderEx convenience methods don't need to run on the MCT.
      LineSegment lineFromMapPoint = LineBuilderEx.CreateLineSegment(startPt, endPt);
      // coordinate2D
      Coordinate2D start2d = (Coordinate2D)startPt;
      Coordinate2D end2d = (Coordinate2D)endPt;
      LineSegment lineFromCoordinate2D = LineBuilderEx.CreateLineSegment(start2d, end2d);
      // coordinate3D
      Coordinate3D start3d = (Coordinate3D)startPt;
      Coordinate3D end3d = (Coordinate3D)endPt;
      LineSegment lineFromCoordinate3D = LineBuilderEx.CreateLineSegment(start3d, end3d);
      // lineSegment
      LineSegment anotherLineFromLineSegment = LineBuilderEx.CreateLineSegment(lineFromCoordinate3D);
      // builderEx constructors don't need to run on the MCT
      LineBuilderEx lbEx = new LineBuilderEx(startPt, endPt);
      lineFromMapPoint = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(start2d, end2d);
      lineFromCoordinate2D = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(start3d, end3d);
      lineFromCoordinate3D = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(lineFromCoordinate3D);
      anotherLineFromLineSegment = lbEx.ToSegment() as LineSegment;
    Requirements
