ArcGIS.Core.Geometry Namespace / LineBuilderEx Class / CreateLineSegment Method / CreateLineSegment(Coordinate2D,Coordinate2D,SpatialReference) Method
The start point.
The end point.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a new instance of the LineSegment class.
    Syntax
    Public Overloads Shared Function CreateLineSegment( _
       ByVal startPoint As Coordinate2D, _
       ByVal endPoint As Coordinate2D, _
       Optional ByVal spatialReference As SpatialReference _
    ) As LineSegment
    Parameters
    startPoint
    The start point.
    endPoint
    The end point.
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    startPoint or endPoint is null or empty.
    Remarks
    The new instance will build a straight line segment between the start and end point.
    Line Segment
    Example
    Construct a LineSegment using two MapPoints
      // Use a builderEx convenience method or use a builderEx constructor.
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      // BuilderEx convenience methods don't need to run on the MCT.
      LineSegment lineFromMapPoint = LineBuilderEx.CreateLineSegment(startPt, endPt);
      // coordinate2D
      Coordinate2D start2d = (Coordinate2D)startPt;
      Coordinate2D end2d = (Coordinate2D)endPt;
      LineSegment lineFromCoordinate2D = LineBuilderEx.CreateLineSegment(start2d, end2d);
      // coordinate3D
      Coordinate3D start3d = (Coordinate3D)startPt;
      Coordinate3D end3d = (Coordinate3D)endPt;
      LineSegment lineFromCoordinate3D = LineBuilderEx.CreateLineSegment(start3d, end3d);
      // lineSegment
      LineSegment anotherLineFromLineSegment = LineBuilderEx.CreateLineSegment(lineFromCoordinate3D);
      // builderEx constructors don't need to run on the MCT
      LineBuilderEx lbEx = new LineBuilderEx(startPt, endPt);
      lineFromMapPoint = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(start2d, end2d);
      lineFromCoordinate2D = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(start3d, end3d);
      lineFromCoordinate3D = lbEx.ToSegment() as LineSegment;
      lbEx = new LineBuilderEx(lineFromCoordinate3D);
      anotherLineFromLineSegment = lbEx.ToSegment() as LineSegment;
    Construct a Circular Arc - using two segments and radius
      // Construct a segment from (100, 100) to (50, 50) and another segment from (100, 100) to (150, 50).
      LineSegment segment1 = LineBuilderEx.CreateLineSegment(new Coordinate2D(100, 100), new Coordinate2D(50, 50));
      LineSegment segment2 = LineBuilderEx.CreateLineSegment(new Coordinate2D(100, 100), new Coordinate2D(150, 50));
      // Construct the hint point to determine where the arc will be constructed.
      Coordinate2D hintPoint = new Coordinate2D(100, 75);
      // Call QueryFilletRadius to get the minimum and maximum radii that can be used with these segments.
      var minMaxRadii = EllipticArcBuilderEx.QueryFilletRadiusRange(segment1, segment2, hintPoint);
      // Use the maximum radius to create the arc.
      double maxRadius = minMaxRadii.Item2;
      //At 2.x - EllipticArcSegment circularArc = EllipticArcBuilderEx.CreateEllipticArcSegment(segment1, segment2, maxRadius, hintPoint);
      EllipticArcSegment circularArc = EllipticArcBuilderEx.CreateCircularArc(
      // This EllipticArcBuilderEx constructor needs to run on the MCT either.
      EllipticArcBuilderEx cab = new EllipticArcBuilderEx(segment1, segment2, maxRadius, hintPoint);
      EllipticArcSegment otherCircularArc = cab.ToSegment();
    Clip a Polyline
      // clip a polyline by an envelope
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(2.0, 2.0, 4.0, 4.0);
      LineSegment line = LineBuilderEx.CreateLineSegment(new Coordinate2D(0, 3), new Coordinate2D(5.0, 3.0));
      polyline = PolylineBuilderEx.CreatePolyline(line);
      Geometry clipGeom = GeometryEngine.Instance.Clip(polyline, env);
    QueryPoint
      SpatialReference sr = SpatialReferences.WGS84;
      // Horizontal line segment
      Coordinate2D start = new(1, 1);
      Coordinate2D end = new(11, 1);
      LineSegment line = LineBuilderEx.CreateLineSegment(start, end, sr);
      // Don't extend the segment
      MapPoint outPoint = GeometryEngine.Instance.QueryPoint(polyline, SegmentExtensionType.NoExtension, 1.0, AsRatioOrLength.AsLength);
      // outPoint = (2, 1)
      // or the segment
      MapPoint outPoint_seg = GeometryEngine.Instance.QueryPoint(line, SegmentExtensionType.NoExtension, 1.0, AsRatioOrLength.AsLength);
      // outPoint_seg = (2, 1)
      // Extend infinitely in both directions
      outPoint = GeometryEngine.Instance.QueryPoint(polyline, SegmentExtensionType.ExtendTangents, 1.5, AsRatioOrLength.AsRatio);
      // outPoint = (16, 1)
      outPoint_seg = GeometryEngine.Instance.QueryPoint(line, SegmentExtensionType.ExtendTangents, 1.5, AsRatioOrLength.AsRatio);
      // outPoint_seg = (16, 1)
    QueryTangent
      LineSegment line = LineBuilderEx.CreateLineSegment(new Coordinate2D(0, 0), new Coordinate2D(1, 0));
      // No extension, distanceAlongCurve = 0.5
      LineSegment tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.NoExtension, 0.5, AsRatioOrLength.AsRatio, 1);
      // tangent.StartCoordinate = (0.5, 0.0)
      // tangent.EndCoordinate = (1.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.NoExtension, 1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (1.0, 0.0)
      // tangent.EndCoordinate = (2.0, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtTo, 1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (1.5, 0.0)
      // tangent.EndCoordinate = (2.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtFrom, -1.5, AsRatioOrLength.AsLength, 1);
      // tangent.StartCoordinate = (-1.5, 0.0)
      // tangent.EndCoordinate = (-0.5, 0.0)
      tangent = GeometryEngine.Instance.QueryTangent(line, SegmentExtensionType.ExtendTangentAtFrom, -0.5, AsRatioOrLength.AsRatio, 1);
      // tangent.StartCoordinate = (-0.5, 0.0)
      // tangent.EndCoordinate = (0.5, 0.0)
    Reflect a polygon about a line
      Coordinate2D start = new(0, 0);
      Coordinate2D end = new(4, 4);
      Coordinate2D[] coords =
        new Coordinate2D(-1, 2),
      new Coordinate2D(-1, 4),
      new Coordinate2D(1, 4),
      polygon = PolygonBuilderEx.CreatePolygon(coords, sr);
      // reflect a polygon about the line
      Polygon reflectedPolygon = GeometryEngine.Instance.ReflectAboutLine(polygon, line) as Polygon;
      // reflectedPolygon points are
      //    (2, -1), (4, -1), (4, 1), (2, -1)
    Determine relationship between two geometries
      // set up some geometries
      // points
      MapPoint point0 = MapPointBuilderEx.CreateMapPoint(0, 0, SpatialReferences.WGS84);
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(1, 1, SpatialReferences.WGS84);
      MapPoint point2 = MapPointBuilderEx.CreateMapPoint(-5, 5, SpatialReferences.WGS84);
      // multipoint
      List<MapPoint> points = [point0, point1, point2];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(points, SpatialReferences.WGS84);
      // polygon
      List<Coordinate2D> polygonCoords =
          new Coordinate2D(-10, 0),
      new Coordinate2D(0, 10),
      new Coordinate2D(10, 0),
      polygon = PolygonBuilderEx.CreatePolygon(polygonCoords, SpatialReferences.WGS84);
      // polylines
      Polyline polyline1 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-9.1, 0.1), new Coordinate2D(0, 9)), SpatialReferences.WGS84);
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-5, 5), new Coordinate2D(0, 5)), SpatialReferences.WGS84);
      Polyline polyline3 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(2.09, -2.04), new Coordinate2D(5, 10)), SpatialReferences.WGS84);
      Polyline polyline4 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(10, -5), new Coordinate2D(10, 5)), SpatialReferences.WGS84);
      List<Segment> segments =
          LineBuilderEx.CreateLineSegment(new Coordinate2D(5.05, -2.87), new Coordinate2D(6.35, 1.57)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(6.35, 1.57), new Coordinate2D(4.13, 2.59)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(4.13, 2.59), new Coordinate2D(5, 5))
      Polyline polyline5 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)));
      Polyline polyline6 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      Polyline polyline7 = PolylineBuilderEx.CreatePolyline(polyline5);
      Polyline polyline8 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)), SpatialReferences.WGS84);
      segments.Clear();
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.6, 3.5), new Coordinate2D(0.7, 7)));
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.7, 7), new Coordinate2D(3, 9)));
      Polyline polyline9 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      // now do the Related tests
      // Interior/Interior Intersects
      string scl = "T********";
      bool related = GeometryEngine.Instance.Relate(polygon, polyline1, scl);     // related = true
      related = GeometryEngine.Instance.Relate(point0, point1, scl);              // related = false
      related = GeometryEngine.Instance.Relate(point0, multipoint, scl);          // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polygon, scl);         // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polyline1, scl);       // related = false
      related = GeometryEngine.Instance.Relate(polyline2, point2, scl);           // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = true
      // Interior/Boundary Intersects
      scl = "*T*******";
      related = GeometryEngine.Instance.Relate(polygon, polyline2, scl);          // related = true
      related = GeometryEngine.Instance.Relate(polygon, polyline3, scl);          // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = false
      // Boundary/Boundary Interior intersects
      scl = "***T*****";
      related = GeometryEngine.Instance.Relate(polygon, polyline4, scl);          // related = true
      // Overlaps Dim1
      scl = "1*T***T**";
      related = GeometryEngine.Instance.Relate(polygon, polyline5, scl);          // related = true
      // Crosses Area/Line (LineB crosses PolygonA)
      scl = "1020F1102";
      related = GeometryEngine.Instance.Relate(polygon, polyline6, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline9, scl);          // related = true
      // Boundary/Boundary Touches
      scl = "F***T****";
      related = GeometryEngine.Instance.Relate(polygon, polyline7, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline8, scl);          // related = true
    Requirements
