ArcGIS.Core.Geometry Namespace / MultipartBuilderEx Class / InsertSegment Method / InsertSegment(Int32,Int32,Segment) Method
The index of the part into which the segment will inserted. Must be less than PartCount. Specify -1 or (PartCount - 1) to remove the last part.
The index before which the segment will be inserted. Must be less than or equal to GetSegmentCount(partIndex). The segment to insert. part at the end of the Parts list.
    Inserts a segment into an existing part.
    Syntax
    public void InsertSegment(
       int partIndex,
       int beforeSegmentIndex,
       Segment segment
    Public Overloads Sub InsertSegment( _
       ByVal partIndex As Integer, _
       ByVal beforeSegmentIndex As Integer, _
       ByVal segment As Segment _
    Parameters
    partIndex
    beforeSegmentIndex
    segment
    Exceptions
    ExceptionDescription
    segment is null.
    partIndex is greater than PartCount - 1 or beforeSegmentIndex is greater than GetSegmentCount(partIndex).
    Remarks
    The spatial reference of the segment is ignored, and the attribute of the segment does not affect the attribute awareness of the builder. However, if the builder has an attribute and the start or end point of a segment also has that attribute, then the attribute value will be taken from the point. If the point doesn't have that attribute, then a default value will be set in the builder. For example, suppose the HasZ property of the builder is set to true. If the HasZ property of a point is set to true, then the point's Z-value is used. Otherwise, the default value is used. The default value for Z is 0, for M is NaN and for ID is 0.
    Requirements
