ArcGIS.Core.Geometry Namespace / MultipartBuilderEx Class
Members
    An abstract base class for creating a Polyline or a Polygon.
    Object Model
    MultipartBuilderEx ClassSegment ClassSpatialReference ClassGeometry Class
    Syntax
    Public MustInherit Class MultipartBuilderEx
       Inherits GeometryBuilderEx
    public abstract class MultipartBuilderEx : GeometryBuilderEx
    Remarks
    Use the MultipartBuilderEx class to to create and/or modify a base Multipart shape. The builder is best suited for editing workflows where the user may be adding, inserting or removing parts of a Multipart geometry interactively. A Multipart is based upon the parent Geometry class. The Geometry class is immutable which means that you can not change its shape once it is created. Hence, the MultipartBuilderEx provides the way to make changes when working with a Multipart. Use the PolylineBuilderEx.ToGeometry or PolygonBuilderEx.ToGeometry method to get the Multipart from the builder.
    The MultipointBuilderEx methods can be called on any thread.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Geometry.GeometryBuilderEx
          ArcGIS.Core.Geometry.MultipartBuilderEx
             ArcGIS.Core.Geometry.PolygonBuilderEx
             ArcGIS.Core.Geometry.PolylineBuilderEx
    Requirements
