ArcGIS.Core.Geometry Namespace / MultipartBuilderEx Class / RemovePart Method
The index of the part to remove. Must be less than PartCount. Specify -1 or (PartCount - 1) to remove the last part.
Example
    RemovePart Method
    Remove the part specified by partIndex.
    Syntax
    public void RemovePart(
       int partIndex
    Public Sub RemovePart( _
       ByVal partIndex As Integer _
    Parameters
    partIndex
    Exceptions
    ExceptionDescription
    partIndex is greater than PartCount - 1.
    Example
    Build a multi-part Polyline
      List<MapPoint> firstPoints = new List<MapPoint>();
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 1.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 1.0));
      List<MapPoint> nextPoints = new List<MapPoint>();
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 1.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 1.0));
      // use AttributeFlags.None since we have 2D points in the list
      PolylineBuilderEx pBuilder = new PolylineBuilderEx(firstPoints, AttributeFlags.None);
      pBuilder.AddPart(nextPoints);
      Polyline polylineFromBuilder = pBuilder.ToGeometry();
      // polyline has 2 parts
      pBuilder.RemovePart(0);
      // polyline has 1 part
    Requirements
