Public NotInheritable Class ParcelFabric Inherits ArcGIS.Core.Data.Dataset Implements System.IDisposable
public sealed class ParcelFabric : ArcGIS.Core.Data.Dataset, System.IDisposable
string errorMessage = await QueuedTask.Run(() =>
try
var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric in the map.";
var myParcelFabricDataset = myParcelFabricLayer.GetParcelFabric();
catch (Exception ex)
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Get Parcel Fabric Dataset from layer.");
try
var myTopology = myParcelFabricDataset.GetParcelTopology();
return ex.Message;
return "";
MessageBox.Show(errorMessage, "Get Parcel Fabric Topology.");
var parcelFabricDataset = await QueuedTask.Run(() =>
ParcelFabric myParcelFabricDataset = null;
if (table.IsControllerDatasetSupported())
// Tables can belong to multiple controller datasets, but at most one of them will be a parcel fabric
IReadOnlyList<Dataset> controllerDatasets = table.GetControllerDatasets();
foreach (Dataset controllerDataset in controllerDatasets)
if (controllerDataset is ParcelFabric)
myParcelFabricDataset = controllerDataset as ParcelFabric;
else
controllerDataset.Dispose();
return myParcelFabricDataset;
System.Object
ArcGIS.Core.CoreObjectsBase
ArcGIS.Core.Data.Parcels.ParcelFabric
