Parameters
- name
- The name of the dataset to open.
Type Parameters
- T
- The type of dataset to open.
| Exception | Description |
| System.InvalidOperationException | No valid geodatabase has been opened prior to calling this operation. -or- The dataset type corresponding to T is not supported (see DatasetType). -or- Using AttributedRelationshipClass as T to open a dataset whose type is actually DatasetType.RelationshipClass. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. For example, the name is invalid. |
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (Table table = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.EmployeeInfo"))
// Open a featureClass (within a feature dataset or outside a feature dataset).
using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.AddressPoint"))
// Open a FeatureClass as a Table which will return the Table reference.
using (Table featureClassAsTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.AddressPoint"))
// But it is really a FeatureClass object.
FeatureClass featureClassOpenedAsTable = featureClassAsTable as FeatureClass;
// Open a FeatureDataset.
using (FeatureDataset featureDataset = geodatabase.OpenDataset<FeatureDataset>("LocalGovernment.GDB.Address"))
// Open a RelationshipClass. Just as you can open a FeatureClass as a Table, you can also open an AttributedRelationshipClass as a RelationshipClass.
using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
//Url examples for (federated) feature services
//(federated by ref on portal)
var url =
@"https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer";
//(federated by value - Hosted - on portal)
//https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer
var uri = new Uri(url, UriKind.Absolute);
using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
using (FeatureClass featureClass = fs_db.OpenDataset<FeatureClass>("0"))
// Use the feature class opened from layer ID 0.
using (Table table = fs_db.OpenDataset<Table>("4"))
// Use the table opened from layer ID 4.
using (AttributedRelationshipClass attributedRelationshipClass =
fs_db.OpenDataset<AttributedRelationshipClass>("5"))
// Use the attributed relationship class opened from layer ID 5.
try
string idOfLayerWhichIsNotTable = "3";
fs_db.OpenDataset<Table>(idOfLayerWhichIsNotTable);
catch (InvalidOperationException)
// Handle Exception.
try
using (Table table = geodatabase.OpenDataset<Table>("EmployeeInfo"))
QueryFilter queryFilter = new QueryFilter
WhereClause = "COSTCTRN = 'Information Technology'",
SubFields = "KNOWNAS, OFFICE, LOCATION",
PostfixClause = "ORDER BY OFFICE"
using (RowCursor rowCursor = table.Search(queryFilter, false))
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
string location = Convert.ToString(row["LOCATION"]);
string knownAs = Convert.ToString(row["KNOWNAS"]);
catch (GeodatabaseFieldException fieldException)
// One of the fields in the where clause might not exist. There are multiple ways this can be handled:
// Handle error appropriately
using (Table table = geodatabase.OpenDataset<Table>("TableWithChineseCharacters"))
// This will fail with many database systems that expect Latin characters by default
string incorrectWhereClause = "颜色 = '绿'";
// Correct solution is to prepend the 'National String Prefix' to the attribute value
// For example, with SQL Server this value is 'N'
// This value is obtained using the SQLSyntax class
string nationalStringPrefix = "";
SQLSyntax sqlSyntax = geodatabase.GetSQLSyntax();
nationalStringPrefix = sqlSyntax.GetSupportedStrings(SQLStringType.NationalStringPrefix).First();
// This Where clause will work
QueryFilter queryFilter = new QueryFilter()
WhereClause = "颜色 = " + nationalStringPrefix + "'绿'"
using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary"))
// Using a spatial query filter to find all features which have a certain district name and lying within a given Polygon.
SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
WhereClause = "DISTRCTNAME = 'Indian Prairie School District 204'",
FilterGeometry = new PolygonBuilderEx(new List<Coordinate2D>
new Coordinate2D(1021880, 1867396),
new Coordinate2D(1028223, 1870705),
new Coordinate2D(1031165, 1866844),
new Coordinate2D(1025373, 1860501),
new Coordinate2D(1021788, 1863810)
}).ToGeometry(),
SpatialRelationship = SpatialRelationship.Within
using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false))
while (indianPrairieCursor.MoveNext())
using (Feature feature = (Feature)indianPrairieCursor.Current)
// Process the feature. For example...
Console.WriteLine(feature.GetObjectID());
using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
// For Selecting all matching entries.
using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal))
// This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
// This can be used to obtain a empty selection which can be used as a container to combine results from different selections.
using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty))
// If you want to select all the records in a table.
using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
List<Coordinate2D> newCoordinates = new List<Coordinate2D>
new Coordinate2D(1021570, 1880583),
new Coordinate2D(1028730, 1880994),
new Coordinate2D(1029718, 1875644),
new Coordinate2D(1021405, 1875397)
SpatialQueryFilter spatialFilter = new SpatialQueryFilter
WhereClause = "FCODE = 'Park'",
FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
SpatialRelationship = SpatialRelationship.Crosses
using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
// criteria is selected.
using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
// This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Data\\LocalGovernment.gdb"))))
using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("FacilitySite"))
string substringFunctionName = sqlSyntax.GetFunctionName(SQLFunction.Substring);
string upperFunctionName = sqlSyntax.GetFunctionName(SQLFunction.Upper);
string substringfunction = string.Format("{0}({1}(FCODE, 1, 6)) = 'SCHOOL'", upperFunctionName,
substringFunctionName);
WhereClause = substringfunction
using (Selection selection =
featureClass.Select(queryFilter, SelectionType.ObjectID, SelectionOption.Normal))
// work with the selection.
using (Table table = geodatabase.OpenDataset<Table>("WaterPipeInfo"))
using (TableDefinition tableDefinition = table.GetDefinition())
bool supportsFullText = geodatabase.GetDatastoreProperties().SupportsFullTextIndex;
if (!supportsFullText)
return;
IReadOnlyList<Index> indexes = tableDefinition.GetIndexes();
IReadOnlyList<Field> fieldsToSearch = indexes.First().GetFields();
FullTextSearchTermExpression searchRepairStatus = new FullTextSearchTermExpression()
SearchFields = fieldsToSearch[0].Name,
SearchTerm = "Repaired",
SearchType = FullTextSearchType.Simple
FullTextSearchTermExpression searchPipeMaterial = new FullTextSearchTermExpression()
SearchFields = fieldsToSearch[1].Name,
SearchTerm = "Copper",
FullTextOrExpression repairedOrCopperEx = new FullTextOrExpression(searchRepairStatus, searchPipeMaterial);
QueryFilter queryfilter = new QueryFilter
FullTextExpression = repairedOrCopperEx,
Offset = 1,
RowCount = 20,
PostfixClause = "Order By Size"
using (RowCursor rowCursor = table.Search(queryfilter, false))
// Use row cursor ...
using (Database database = new Database(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
AuthenticationMode = AuthenticationMode.DBMS,
Instance = "instance",
User = "user",
Password = "password",
Database = "database"
using (FeatureClass leftFeatureClass = geodatabase.OpenDataset<FeatureClass>("Hospital"))
using (Table rightTable = database.OpenTable(database.GetQueryDescription("FacilitySite")))
Field originPrimaryKey = leftFeatureClass.GetDefinition().GetFields()
.FirstOrDefault(field => field.Name.Equals("facilityId"));
Field destinationForeignKey = rightTable.GetDefinition().GetFields()
.FirstOrDefault(field => field.Name.Equals("hospitalID"));
VirtualRelationshipClassDescription description = new VirtualRelationshipClassDescription(
originPrimaryKey, destinationForeignKey, RelationshipCardinality.OneToOne);
using (RelationshipClass relationshipClass = leftFeatureClass.RelateTo(rightTable, description))
JoinDescription joinDescription = new JoinDescription(relationshipClass)
JoinDirection = JoinDirection.Forward,
JoinType = JoinType.LeftOuterJoin
Join join = new Join(joinDescription);
using (Table joinedTable = join.GetJoinedTable())
// Perform operation on joined table.
using (Geodatabase sourceGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ one"))))
using (Geodatabase destinationGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ two"))))
using (Table sourceTable = sourceGeodatabase.OpenDataset<Table>("State"))
using (Table destinationTable = destinationGeodatabase.OpenDataset<Table>("Cities"))
Field primaryKeyField = sourceTable.GetDefinition().GetFields()
.FirstOrDefault(field => field.Name.Equals("State.State_Abbreviation"));
Field foreignKeyField = destinationTable.GetDefinition().GetFields()
.FirstOrDefault(field => field.Name.Equals("Cities.State"));
VirtualRelationshipClassDescription virtualRelationshipClassDescription = new VirtualRelationshipClassDescription(primaryKeyField, foreignKeyField,
RelationshipCardinality.OneToMany);
using (RelationshipClass relationshipClass = sourceTable.RelateTo(destinationTable, virtualRelationshipClassDescription))
JoinType = JoinType.InnerJoin,
TargetFields = sourceTable.GetDefinition().GetFields()
using (Join join = new Join(joinDescription))
Table joinedTable = join.GetJoinedTable();
//Process the joined table. For example ..
using (RowCursor cursor = joinedTable.Search())
while (cursor.MoveNext())
using (Row row = cursor.Current)
// Use Row
Task GetVersionConflictsInfoInUpdateDeleteTypeAsync(
ServiceConnectionProperties featureServiceConnectionProperties,
string featureClassName) => QueuedTask.Run(() =>
// To illustrate the conflict between versions,
// the feature is updated in the child version and deleted in the parent version.
long featureObjectIDForEdit = Int64.MinValue;
// Get branch versioned service
using (Geodatabase fsGeodatabase = new Geodatabase(featureServiceConnectionProperties))
using (VersionManager versionManager = fsGeodatabase.GetVersionManager())
using (Version defaultVersion = versionManager.GetDefaultVersion())
using (Geodatabase defaultGeodatabase = defaultVersion.Connect())
using (FeatureClass defaultFeatureClass = defaultGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (FeatureClassDefinition defaultFeatureClassDefinition = defaultFeatureClass.GetDefinition())
// Create a feature in the default version to edit in a branch
defaultGeodatabase.ApplyEdits(() =>
using (RowBuffer rowBuffer = defaultFeatureClass.CreateRowBuffer())
rowBuffer["NAME"] = "Loblolly Pine";
rowBuffer["TREEAGE"] = 1;
rowBuffer[defaultFeatureClassDefinition.GetShapeField()] = new MapPointBuilderEx(new Coordinate2D(1, 1),
SpatialReferenceBuilder.CreateSpatialReference(4152, 0)).ToGeometry();
using (Feature feature = defaultFeatureClass.CreateRow(rowBuffer))
featureObjectIDForEdit = feature.GetObjectID();
// Add newly created feature in the filter
QueryFilter queryFilter = new QueryFilter { ObjectIDs = new List<long> { featureObjectIDForEdit } };
// Create a branch version
VersionDescription versionDescription = new VersionDescription("UpdateDeleteConflictType",
"Update-Delete version conflict type", VersionAccessType.Public);
// Edit the feature in the branch
using (Version editVersion = versionManager.CreateVersion(versionDescription))
using (Geodatabase branchGeodatabase = editVersion.Connect())
using (FeatureClass featureClass = branchGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
branchGeodatabase.ApplyEdits(() =>
row["TREEAGE"] = 100;
row["NAME"] = $"{row["Name"]}_EditInBranch";
row.Store();
// Delete the feature from the default version
defaultFeatureClass.DeleteRows(queryFilter);
// Reconcile options
ReconcileOptions reconcileOptions = new ReconcileOptions(defaultVersion)
ConflictResolutionType = ConflictResolutionType.FavorEditVersion,
ConflictDetectionType = ConflictDetectionType.ByRow,
ConflictResolutionMethod = ConflictResolutionMethod.Continue
// Reconcile with default
ReconcileResult reconcileResult = editVersion.Reconcile(reconcileOptions);
// Check for conflicts
bool hasConflictsReconcileResults = reconcileResult.HasConflicts;
bool hasConflictsAfterReconcile = editVersion.HasConflicts();
// Fetch conflicts
IReadOnlyList<Conflict> conflictsAfterReconcile = editVersion.GetConflicts();
// Iterate conflicts
foreach (Conflict conflict in conflictsAfterReconcile)
// Object ID of row where conflict occurs
long objectId = conflict.ObjectID;
ConflictType conflictType = conflict.ConflictType;
IReadOnlyList<FieldValue> ancestorVersionValues = conflict.AncestorVersionValues;
object nameAncestor = ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeAncestor =
ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> childVersionValues = conflict.ChildVersionValues;
object nameChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> parentVersionValues = conflict.ParentVersionValues;
IReadOnlyList<Field> originalFields = defaultFeatureClassDefinition.GetFields();
string datasetName = conflict.DatasetName;
string message = String.Empty;
bool creationResult = false;
EditOperation editOperation = new EditOperation();
// Declare the callback here. We are not executing it .yet.
editOperation.Callback(context =>
TableDefinition tableDefinition = enterpriseTable.GetDefinition();
int assetNameIndex = tableDefinition.FindField("ASSETNA");
using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
// Either the field index or the field name can be used in the indexer.
rowBuffer[assetNameIndex] = "wMain";
rowBuffer["COST"] = 700;
rowBuffer["ACTION"] = "Open Cut";
// subtype value for "Abandon".
rowBuffer[tableDefinition.GetSubtypeField()] = 3;
using (Row row = enterpriseTable.CreateRow(rowBuffer))
// To Indicate that the attribute table has to be updated.
context.Invalidate(row);
}, enterpriseTable);
try
creationResult = editOperation.Execute();
if (!creationResult)
message = editOperation.ErrorMessage;
catch (GeodatabaseException exObj)
message = exObj.Message;
if (!string.IsNullOrEmpty(message))
Debug.WriteLine(message);
//Declare the callback here. We are not executing it yet
FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
int facilityIdIndex = facilitySiteDefinition.FindField("FACILITYID");
using (RowBuffer rowBuffer = enterpriseFeatureClass.CreateRowBuffer())
rowBuffer[facilityIdIndex] = "wMain";
rowBuffer["NAME"] = "Griffith Park";
rowBuffer["OWNTYPE"] = "Municipal";
rowBuffer["FCODE"] = "Park";
// Add it to Attractions Subtype.
rowBuffer[facilitySiteDefinition.GetSubtypeField()] = 820;
rowBuffer[facilitySiteDefinition.GetShapeField()] = new PolygonBuilderEx(newCoordinates).ToGeometry();
using (Feature feature = enterpriseFeatureClass.CreateRow(rowBuffer))
//To Indicate that the attribute table has to be updated
context.Invalidate(feature);
}, enterpriseFeatureClass);
try
bool modificationResult = false;
QueryFilter openCutFilter = new QueryFilter { WhereClause = "ACTION = 'Open Cut'" };
using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false))
int subtypeFieldIndex = tableDefinition.FindField(tableDefinition.GetSubtypeField());
// In order to update the Map and/or the attribute table.
// Has to be called before any changes are made to the row.
row["ASSETNA"] = "wMainOpenCut";
if (Convert.ToDouble(row["COST"]) > 700)
// Abandon asset if cost is higher than 700 (if that is what you want to do).
row["ACTION"] = "Open Cut Abandon";
row[subtypeFieldIndex] = 3; //subtype value for "Abandon"
//After all the changes are done, persist it.
row.Store();
// Has to be called after the store too.
try
modificationResult = editOperation.Execute();
if (!modificationResult)
int ownTypeIndex = facilitySiteDefinition.FindField("OWNTYPE");
int areaIndex = facilitySiteDefinition.FindField(facilitySiteDefinition.GetAreaField());
WhereClause = "FCODE = 'Hazardous Materials Facility' AND OWNTYPE = ' '"
using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false))
using (Feature feature = (Feature)rowCursor.Current)
// Transfer all Hazardous Material Facilities to the City.
feature[ownTypeIndex] = "Municipal";
if (Convert.ToDouble(feature[areaIndex]) > 50000)
// Set the Shape of the feature to whatever you need.
feature.SetShape(new PolygonBuilderEx(newCoordinates).ToGeometry());
feature.Store();
try
bool deletionResult = false;
// In order to update the Map and/or the attribute table. Has to be called before the delete.
row.Delete();
try
deletionResult = editOperation.Execute();
if (!deletionResult)
using (FeatureClass parkFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.Park"))
QueryFilter filter = new QueryFilter { WhereClause = "NUMPARKING > 0" };
using (RowCursor parkingCursor = parkFeatureClass.Search(filter, false))
while (parkingCursor.MoveNext())
using (MemoryStream stream = CreateMemoryStreamFromContentsOf("Sample.xml"))
Attachment attachment = new Attachment("Sample.xml", "text/xml", stream);
using (Row row = parkingCursor.Current)
long attachmentId = row.AddAttachment(attachment);
// Helper method to read a file into a memory stream
MemoryStream CreateMemoryStreamFromContentsOf(String fileNameWithPath)
MemoryStream memoryStream = new MemoryStream();
using (FileStream file = new FileStream(fileNameWithPath, FileMode.Open, FileAccess.Read))
byte[] bytes = new byte[file.Length];
file.Read(bytes, 0, (int)file.Length);
memoryStream.Write(bytes, 0, (int)file.Length);
return memoryStream;
using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
while (landUseCursor.MoveNext())
using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
foreach (Attachment attachmentToUpdate in filteredAttachments)
attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
rezoningUseCase.UpdateAttachment(attachmentToUpdate);
using (Table inspectionTable = geodatabase.OpenDataset<Table>("luCodeInspection"))
QueryFilter queryFilter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
using (RowCursor cursor = inspectionTable.Search(queryFilter, false))
using (Row currentRow = cursor.Current)
IReadOnlyList<Attachment> rowAttachments = currentRow.GetAttachments(null, true);
IEnumerable<Attachment> attachments = rowAttachments.Where(attachment =>
attachment.GetContentType().Equals("application/pdf"));
IReadOnlyList<long> attachmentIDs =
attachments.Select(attachment => attachment.GetAttachmentID()) as IReadOnlyList<long>;
IReadOnlyDictionary<long, Exception> failures = currentRow.DeleteAttachments(attachmentIDs);
if (failures.Count > 0)
//process errors
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.luCodeViolationHasInspections"))
using (FeatureClass violationsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.luCodeViolation"))
using (Table inspectionTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.luCodeInspection"))
List<Row> jeffersonAveViolations = new List<Row>();
QueryFilter queryFilter = new QueryFilter { WhereClause = "LOCDESC LIKE '%Jefferson%'" };
using (RowCursor rowCursor = violationsFeatureClass.Search(queryFilter, false))
jeffersonAveViolations.Add(rowCursor.Current);
IReadOnlyList<Row> relatedOriginRows = null;
IReadOnlyList<Row> relatedDestinationRows = null;
try
QueryFilter filter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
using (Selection selection = inspectionTable.Select(filter, SelectionType.ObjectID, SelectionOption.Normal))
relatedOriginRows = relationshipClass.GetRowsRelatedToDestinationRows(selection.GetObjectIDs());
bool containsJeffersonAve = relatedOriginRows.Any(row => Convert.ToString(row["LOCDESC"]).Contains("Jefferson"));
List<long> jeffersonAveViolationObjectIds = jeffersonAveViolations.Select(row => row.GetObjectID()).ToList();
relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(jeffersonAveViolationObjectIds);
bool hasFirstNoticeInspections = relatedDestinationRows.Any(row => Convert.ToString(row["ACTION"]).Contains("1st Notice"));
finally
Dispose(jeffersonAveViolations);
Dispose(relatedOriginRows);
Dispose(relatedDestinationRows);
void Dispose(IEnumerable<Row> rows)
foreach (Row row in rows)
row.Dispose();
using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.OverviewToProject"))
using (FeatureClass projectsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjects"))
using (FeatureClass overviewFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview"))
// This will be PROJNAME. This can be used to get the field index or used directly as the field name.
string originKeyField = relationshipClass.GetDefinition().GetOriginKeyField();
// The rows are being added to illustrate adding relationships.
// If one has existing rows, those can be used to add a relationship.
using (RowBuffer projectsRowBuffer = projectsFeatureClass.CreateRowBuffer())
using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer())
projectsRowBuffer["TOTCOST"] = 500000;
overviewRowBuffer[originKeyField] = "LibraryConstruction";
overviewRowBuffer["PROJECTMAN"] = "John Doe";
overviewRowBuffer["FUNDSOUR"] = " ";
using (Row projectsRow = projectsFeatureClass.CreateRow(projectsRowBuffer))
using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer))
Relationship relationship = relationshipClass.CreateRelationship(overviewRow, projectsRow);
//To Indicate that the Map has to draw this feature/row and/or the attribute table has to be updated
context.Invalidate(projectsRow);
context.Invalidate(overviewRow);
context.Invalidate(relationshipClass);
}, projectsFeatureClass, overviewFeatureClass);
bool editResult = editOperation.Execute();
if (!rowCursor.MoveNext())
return;
using (Row jeffersonAveViolation = rowCursor.Current)
IReadOnlyList<Row> relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(new List<long>
{ jeffersonAveViolation.GetObjectID() });
try
foreach (Row relatedDestinationRow in relatedDestinationRows)
try
relationshipClass.DeleteRelationship(jeffersonAveViolation, relatedDestinationRow);
catch (GeodatabaseRelationshipClassException exception)
Console.WriteLine(exception);
}, relationshipClass);
finally
foreach (Row row in relatedDestinationRows)
row.Dispose();
// Insert Cursors are intended for use in CoreHost applications, not Pro Add-ins
using (Table citiesTable = geodatabase.OpenDataset<Table>("name\\of\\cities_table"))
geodatabase.ApplyEdits(() =>
using (InsertCursor insertCursor = citiesTable.CreateInsertCursor())
using (RowBuffer rowBuffer = citiesTable.CreateRowBuffer())
rowBuffer["State"] = "Colorado";
rowBuffer["Name"] = "Fort Collins";
rowBuffer["Population"] = 167830;
insertCursor.Insert(rowBuffer);
rowBuffer["Name"] = "Denver";
rowBuffer["Population"] = 727211;
// Insert more rows here
// A more realistic example would be reading source data from a file
insertCursor.Flush();
Task CreatingAnAnnotationFeatureAsync(Geodatabase geodatabase) => QueuedTask.Run(() =>
using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
annotationFeature.SetAnnotationClassID(0);
annotationFeature.SetStatus(AnnotationStatus.Placed);
// Get the annotation labels from the label collection
IReadOnlyList<CIMLabelClass> labelClasses =
annotationFeatureClassDefinition.GetLabelClassCollection();
// Setup the symbol reference with the symbol id and the text symbol
CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
// Setup the text graphic
CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
cimTextGraphic.Text = "Charlotte, North Carolina";
cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
.ToGeometry();
cimTextGraphic.Symbol = cimSymbolReference;
// Set the symbol reference on the graphic and store
annotationFeature.SetGraphic(cimTextGraphic);
annotationFeature.Store();
using (VersionManager versionManager = geodatabase.GetVersionManager())
IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
Version defaultVersion = versionManager.GetDefaultVersion();
string testVersionName = versionNames.First(v => v.Contains("Test"));
Version testVersion = versionManager.GetVersion(testVersionName);
Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
Geodatabase qaVersionGeodatabase = qaVersion.Connect();
FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
Task IterateDatasetsFromAFeatureDatasetAsync(Geodatabase geodatabase, string featureDatasetName = "City", string featureClassInFeatureDataset = "Buildings") => QueuedTask.Run(() =>
// Open a feature dataset
using (FeatureDataset cityFeatureDataset = geodatabase.OpenDataset<FeatureDataset>(featureDatasetName))
// Get a feature class definition from a feature dataset
FeatureClassDefinition buildingsFeatureClassDefinition = cityFeatureDataset.GetDefinition<FeatureClassDefinition>(featureClassInFeatureDataset);
// Iterate dataset definition
IReadOnlyList<FeatureClassDefinition> cityFeatureClassDefinitions = cityFeatureDataset.GetDefinitions<FeatureClassDefinition>();
foreach (FeatureClassDefinition cityFeatureClassDefinition in cityFeatureClassDefinitions)
// Use feature class definition ...
Task CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDatasetAsync(
// Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
// Feature dataset name
string featureDatasetName = "Places";
// Annotation feature class name
string annotationFeatureClassName = "CitiesAnnotation";
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Open existing annotation feature class name
using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
// Create Feature dataset description
FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
// Add the creation of the Places dataset to DDL task
FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
// Create an annotation feature class description using existing annotation feature class
AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
existingAnnotationFeatureClass.GetDefinition())
IsAutoCreate = true,
IsSymbolIDRequired = false,
IsUpdatedOnShapeChange = true
// Add the creation of the Cities annotation feature class inside Places feature dataset
schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
annotationFeatureClassDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
Task<bool> IsTableVersionedAsync(Geodatabase geodatabase, string tableName) => QueuedTask.Run(() =>
using (Table table = geodatabase.OpenDataset<Table>(tableName))
// Check table version type
RegistrationType registrationType = table.GetRegistrationType();
if (registrationType == RegistrationType.Versioned)
return true;
return false;
// Create a FileGeodatabaseConnectionPath using the path to the gdb. Note: This can be a path to a .sde file.
FileGeodatabaseConnectionPath geodatabaseConnectionPath = new(new Uri(@"C:\Temp\rasters.gdb"));
// Create a new Geodatabase object using the FileGeodatabaseConnectionPath.
Geodatabase geodatabase = new(geodatabaseConnectionPath);
// Open the raster dataset.
RasterDataset gdbRasterDataset = geodatabase.OpenDataset<RasterDataset>("sample");
string path = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb";
var fileConnection = new FileGeodatabaseConnectionPath(new Uri(path));
using (Geodatabase dataStore = new Geodatabase(fileConnection))
string dsName = "nameOfTerrain";
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.Terrain>(dsName))
static void CreateRouteInfo(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string routeIdFieldName = "RouteID")
using (FeatureClass routeFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
using (FeatureClassDefinition routeFeatureClassDefinition = routeFeatureClass.GetDefinition())
if (routeFeatureClassDefinition.HasM())
RouteInfo routeInfo = new RouteInfo(routeFeatureClass, routeIdFieldName);
// Process the routeInfo as needed ...
static void CreateEventInfo(Geodatabase geodatabase, string eventTableName = "Accidents", string routeIdFieldName = "RID", string measureFieldName = "Measure", string offsetFieldName = "Offset")
using (Table eventTable = geodatabase.OpenDataset<Table>(eventTableName))
PointEventInfo eventInfo = new PointEventInfo(eventTable, routeIdFieldName, measureFieldName, offsetFieldName);
// Get event type: Point or Line type
EventType eventTableType = eventInfo.EventType;
static void CreateLineEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure", string offsetFieldName = "Offset")
using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
EventInfo eventInfo = new LineEventInfo(eventsTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName, offsetFieldName);
RouteEventSourceOptions routeEventSourceOptions = new LineEventSourceOptions() { IsPositiveOffsetOnRight = true };
using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
// Locating errors
IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
// Route event source fields
IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
// Add RouteEventSource to the ArcGIS Pro map
FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
Name = "HighCrashAreas"
LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
static void LocateLineFeaturesAlongRoutes(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure")
// Configure events table
EventTableConfiguration lineEventTableConfiguration = new LineEventTableConfiguration(eventTableName, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName) { KeepAllFields = true, MDirectionOffset = true };
using (FeatureClass highCrashAreaFeatureClass = geodatabase.OpenDataset<FeatureClass>("HighCrashRegion"))
// Creates an event table inside the geodatabase
routeInfo.LocateFeatures(highCrashAreaFeatureClass, 0.5, lineEventTableConfiguration);
// Open newly created event table
EventInfo eventInfo = new LineEventInfo(eventTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName);
// Create RouteEventSource using new event table
using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, new LineEventSourceOptions()))
// Process the routeEventSource as needed ...
static void OpenTopologyAndProcessDefinition()
// Open a geodatabase topology from a file geodatabase and process the topology definition.
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
ProcessDefinition(geodatabase, topology);
// Open a feature service topology and process the topology definition.
const string TOPOLOGY_LAYER_ID = "0";
using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
// Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
// definition -- via the Topology dataset itself or via the Geodatabase.
using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
OutputDefinition(geodatabase, definitionViaTopology);
using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
OutputDefinition(geodatabase, definitionViaGeodatabase);
static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
foreach (string name in featureClassNames)
// Open each feature class that participates in the topology.
using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
static void GetTopologyRules()
using (TopologyDefinition topologyDefinition = topology.GetDefinition())
IReadOnlyList<TopologyRule> rules = topologyDefinition.GetRules();
Console.WriteLine($"There are {rules.Count} topology rules defined for the topology:");
Console.WriteLine("ID \t Origin Class \t Origin Subtype \t Destination Class \t Destination Subtype \t Rule Type");
foreach (TopologyRule rule in rules)
Console.Write($"{rule.ID}");
Console.Write(!String.IsNullOrEmpty(rule.OriginClass) ? $"\t{rule.OriginClass}" : "\t\"\"");
Console.Write(rule.OriginSubtype != null ? $"\t{rule.OriginSubtype.GetName()}" : "\t\"\"");
Console.Write(!String.IsNullOrEmpty(rule.DestinationClass) ? $"\t{rule.DestinationClass}" : "\t\"\"");
Console.Write(rule.DestinationSubtype != null ? $"\t{rule.DestinationSubtype.GetName()}" : "\t\"\"");
Console.Write($"\t{rule.RuleType}");
Console.WriteLine();
static void ValidateTopology()
// If the topology currently does not have dirty areas, calling Validate() returns an empty envelope.
ValidationResult result = topology.Validate(new ValidationDescription(topology.GetExtent()));
Console.WriteLine($"'AffectedArea' after validating a topology that has not been edited => {result.AffectedArea.ToJson()}");
// Now create a feature that purposely violates the "PointProperlyInsideArea" topology rule. This action will
// create dirty areas.
Feature newFeature = null;
try
// Fetch the feature in the Campsites feature class whose objectID is 2. Then create a new geometry slightly
// altered from this and use it to create a new feature.
using (Feature featureViaCampsites2 = GetFeature(geodatabase, "Campsites", 2))
Geometry currentGeometry = featureViaCampsites2.GetShape();
Geometry newGeometry = GeometryEngine.Instance.Move(currentGeometry, (currentGeometry.Extent.XMax / 8), (currentGeometry.Extent.YMax / 8));
using (FeatureClass campsitesFeatureClass = featureViaCampsites2.GetTable())
using (FeatureClassDefinition definition = campsitesFeatureClass.GetDefinition())
using (RowBuffer rowBuffer = campsitesFeatureClass.CreateRowBuffer())
rowBuffer[definition.GetShapeField()] = newGeometry;
geodatabase.ApplyEdits(() => { newFeature = campsitesFeatureClass.CreateRow(rowBuffer); });
// After creating a new feature in the 'Campsites' participating feature class, the topology's state should be
// "Unanalyzed" because it has not been validated.
Console.WriteLine($"The topology state after an edit has been applied => {topology.GetState()}");
// Now validate the topology. The result envelope corresponds to the dirty areas.
Console.WriteLine($"'AffectedArea' after validating a topology that has just been edited => {result.AffectedArea.ToJson()}");
// After Validate(), the topology's state should be "AnalyzedWithErrors" because the topology currently has errors.
Console.WriteLine($"The topology state after validate topology => {topology.GetState()}");
// If there are no dirty areas, the result envelope should be empty.
Console.WriteLine($"'AffectedArea' after validating a topology that has just been validated => {result.AffectedArea.ToJson()}");
finally
if (newFeature != null)
geodatabase.ApplyEdits(() => { newFeature.Delete(); });
newFeature.Dispose();
// Validate again after deleting the newly-created feature.
static void ProcessTopologyErrors()
// Get all the errors and exceptions currently associated with the topology.
IReadOnlyList<TopologyError> allErrorsAndExceptions = topology.GetErrors(new ErrorDescription(topology.GetExtent()));
Console.WriteLine($"errors and exceptions count => {allErrorsAndExceptions.Count}");
Console.WriteLine("OriginClassName \t OriginObjectID \t DestinationClassName \t DestinationObjectID \t RuleType \t IsException \t Shape type \t Shape width & height \t Rule ID \t");
foreach (TopologyError error in allErrorsAndExceptions)
Console.WriteLine(
$"'{error.OriginClassName}' \t {error.OriginObjectID} \t '{error.DestinationClassName}' \t " +
$"{error.DestinationObjectID} \t {error.RuleType} \t {error.IsException} \t {error.Shape.GeometryType} \t " +
$"{error.Shape.Extent.Width},{error.Shape.Extent.Height} \t {error.RuleID}");
static void ExploreTopologyGraph()
// Build a topology graph using the extent of the topology dataset.
topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
IReadOnlyList<TopologyNode> topologyNodesViaCampsites12 = topologyGraph.GetNodes(campsites12);
TopologyNode topologyNodeViaCampsites12 = topologyNodesViaCampsites12[0];
IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12 = topologyNodeViaCampsites12.GetEdges();
IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12CounterClockwise = topologyNodeViaCampsites12.GetEdges(false);
foreach (TopologyEdge edgeConnectedToNodeViaCampsites12 in allEdgesConnectedToNodeViaCampsites12)
TopologyNode fromNode = edgeConnectedToNodeViaCampsites12.GetFromNode();
TopologyNode toNode = edgeConnectedToNodeViaCampsites12.GetToNode();
bool fromNodeIsTheSameAsTopologyNodeViaCampsites12 = (fromNode == topologyNodeViaCampsites12);
bool toNodeIsTheSameAsTopologyNodeViaCampsites12 = (toNode == topologyNodeViaCampsites12);
IReadOnlyList<FeatureInfo> leftParentFeaturesBoundedByEdge =
edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures();
foreach (FeatureInfo featureInfo in leftParentFeaturesBoundedByEdge)
EnsureShapeIsNotEmpty(featureInfo);
IReadOnlyList<FeatureInfo> leftParentFeaturesNotBoundedByEdge =
edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures(false);
foreach (FeatureInfo featureInfo in leftParentFeaturesNotBoundedByEdge)
IReadOnlyList<FeatureInfo> rightParentFeaturesBoundedByEdge =
edgeConnectedToNodeViaCampsites12.GetRightParentFeatures();
foreach (FeatureInfo featureInfo in rightParentFeaturesBoundedByEdge)
IReadOnlyList<FeatureInfo> rightParentFeaturesNotBoundedByEdge =
edgeConnectedToNodeViaCampsites12.GetRightParentFeatures(false);
foreach (FeatureInfo featureInfo in rightParentFeaturesNotBoundedByEdge)
static void EnsureShapeIsNotEmpty(FeatureInfo featureInfo)
using (Feature feature = featureInfo.GetFeature())
// Process feature ...
static void FindClosestElement()
MapPoint queryPointViaCampsites12 = null;
queryPointViaCampsites12 = campsites12.GetShape() as MapPoint;
double searchRadius = 1.0;
TopologyElement topologyElementViaCampsites12 = topologyGraph.FindClosestElement<TopologyElement>(queryPointViaCampsites12, searchRadius);
IReadOnlyList<FeatureInfo> parentFeatures = topologyElementViaCampsites12.GetParentFeatures();
Console.WriteLine("The parent features that spawn 'topologyElementViaCampsites12' are:");
foreach (FeatureInfo parentFeature in parentFeatures)
Console.WriteLine($"\t{parentFeature.FeatureClassName}; OID: {parentFeature.ObjectID}");
TopologyNode topologyNodeViaCampsites12 = topologyGraph.FindClosestElement<TopologyNode>(queryPointViaCampsites12, searchRadius);
if (topologyNodeViaCampsites12 != null)
// There exists a TopologyNode nearest to the query point within searchRadius units.
TopologyEdge topologyEdgeViaCampsites12 = topologyGraph.FindClosestElement<TopologyEdge>(queryPointViaCampsites12, searchRadius);
if (topologyEdgeViaCampsites12 != null)
// There exists a TopologyEdge nearest to the query point within searchRadius units.
