Public Function GetParcelTypeInfo() As IReadOnlyList(Of ParcelTypeInfo)
public IReadOnlyList<ParcelTypeInfo> GetParcelTypeInfo()
Return Value
An IEnumerable of ParcelTypeInfo.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
string errorMessage = await QueuedTask.Run(() =>
try
var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric in the map.";
string myParcelTypeName = "Tax";
var myParcelFabricDataset = myParcelFabricLayer.GetParcelFabric();
var typeInfo = myParcelFabricDataset.GetParcelTypeInfo();
FeatureClass lineFCType = null;
FeatureClass polyFCType = null;
foreach (var info in typeInfo)
if (info.Name.Equals(myParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
lineFCType = info.LineFeatureTable as FeatureClass;
polyFCType = info.PolygonFeatureTable as FeatureClass;
break;
catch (Exception ex)
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Get Parcel Type feature classes.");
