ArcGIS.Core.Data.Parcels Namespace / ParcelFabricDefinition Class / GetSchemaVersion Method
    GetSchemaVersion Method (ParcelFabricDefinition)
    Gets the version number of the parcel fabric schema. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSchemaVersion() As String
    public string GetSchemaVersion()
    Return Value
    A string representation of the version of the parcel fabric schema.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    This is the version number shown in the network properties of a parcel fabric layer. Negative numbers indicate pre-release builds.
    Requirements
