ArcGIS.Core.Data.Parcels Namespace / ParcelFabricDefinition Class / GetTopologyEnabled Method
    Gets if the topology is enabled on parcel fabric. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetTopologyEnabled() As Boolean
    public bool GetTopologyEnabled()
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    true if topology is enabled on parcel fabric; otherwise, false.
    Requirements
