public static class ApplicationOptions
Public MustInherit NotInheritable Class ApplicationOptions
var lastToolActive = ApplicationOptions.LayoutOptions.KeepLastToolActive;
var warnOnSurrounds = ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds;
//eg <Install_Path>\Resources\LayoutTemplates\en-US
var gallery_path = ApplicationOptions.LayoutOptions.LayoutTemplatePath;
var defaultGuideColor = ApplicationOptions.LayoutOptions.DefaultGuideColor;
var guideColor = await QueuedTask.Run(() => ApplicationOptions.LayoutOptions.GetGuideColor());
//keep graphic element insert tool active
ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
//no warning when deleting a map frame results in other elements being deleted
ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
//path to .pagx files used as templates
ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
// set guide color
ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
//Note: see also SymbolFactory.Instance.GetAvailableFonts() which returns the
//same list. Use for TextAndGraphicsElementsOptions.GetAvailableFonts() convenience
//A list of tuples of Font name + associated Font Styles, one tuple per
//font, is returned
var fonts = ApplicationOptions.TextAndGraphicsElementsOptions.GetAvailableFonts();
StringBuilder sb = new StringBuilder();
sb.AppendLine("Pro Fonts\r\n============================");
foreach (var font in fonts)
var styles = string.Join(",", font.fontStyles);
sb.AppendLine($"{font.fontName}, [{styles}]");
System.Diagnostics.Debug.WriteLine(sb.ToString());
//Get the default font (see also 'SymbolFactory.Instance.DefaultFont')
var def_font = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultFont();
$"\r\ndefault font: {def_font.fontName}, {def_font.styleName}");
//Get the default graphics element symbols - point, line, poly, text
var ptSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPointSymbol();
var lineSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultLineSymbol();
var polySymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPolygonSymbol();
var textSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultTextSymbol();
//Set a default font. Use its default style
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
//or specify an explicit style
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
//Create symbols
var ptSymbol2 = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.RedRGB, 14, SimpleMarkerStyle.Diamond);
var lineSymbol2 = SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.Dash);
var polySymbol2 = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.RedRGB, SimpleFillStyle.DiagonalCross);
var textSymbol2 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 12);
//Set default point, line, poly, text graphics element symbols
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPointSymbol(ptSymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultLineSymbol(lineSymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPolygonSymbol(polySymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultTextSymbol(textSymbol2);
System.Object
ArcGIS.Desktop.Core.ApplicationOptions
