var lastToolActive = ApplicationOptions.LayoutOptions.KeepLastToolActive;
var warnOnSurrounds = ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds;
//eg <Install_Path>\Resources\LayoutTemplates\en-US
var gallery_path = ApplicationOptions.LayoutOptions.LayoutTemplatePath;
var defaultGuideColor = ApplicationOptions.LayoutOptions.DefaultGuideColor;
//Note: Must be on QueuedTask.Run.
var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
//keep graphic element insert tool active
ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
//no warning when deleting a map frame results in other elements being deleted
ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
//path to .pagx files used as templates
ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
// set guide color
ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
