ArcGIS.Desktop.Core Namespace / LayoutOptions Class / WarnAboutAssociatedSurrounds Property
Example
    Gets and sets whether a warning will be shown when deleting a map frame will result in other elements in the layout being deleted.
    Syntax
    Public Property WarnAboutAssociatedSurrounds As Boolean
    public bool WarnAboutAssociatedSurrounds {get; set;}
    Example
    Get LayoutOptions
      var lastToolActive = ApplicationOptions.LayoutOptions.KeepLastToolActive;
      var warnOnSurrounds = ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds;
      //eg <Install_Path>\Resources\LayoutTemplates\en-US
      var gallery_path = ApplicationOptions.LayoutOptions.LayoutTemplatePath;
      var defaultGuideColor = ApplicationOptions.LayoutOptions.DefaultGuideColor;
      //Note: Must be on QueuedTask.Run.
      var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
    Set LayoutOptions
      //keep graphic element insert tool active
      ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
      //no warning when deleting a map frame results in other elements being deleted
      ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
      //path to .pagx files used as templates
      ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
      // set guide color
      ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
    Requirements
