public CIMPointSymbol GetDefaultPointSymbol()
Public Function GetDefaultPointSymbol() As CIMPointSymbol
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Get the default font (see also 'SymbolFactory.Instance.DefaultFont')
var def_font = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultFont();
System.Diagnostics.Debug.WriteLine(
$"\r\ndefault font: {def_font.fontName}, {def_font.styleName}");
//Get the default graphics element symbols - point, line, poly, text
var ptSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPointSymbol();
var lineSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultLineSymbol();
var polySymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPolygonSymbol();
var textSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultTextSymbol();
