public void SetDefaultFont( string familyName )
Public Overloads Sub SetDefaultFont( _ ByVal familyName As String _ )
Parameters
- familyName
- The font family to set as the default
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | font not found |
var def_font = SymbolFactory.Instance.DefaultFont;
System.Diagnostics.Debug.WriteLine($"{def_font.fontName}, styles: {def_font.styleName}");
//set default font - set through application options
await QueuedTask.Run(() =>
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
