ArcGIS.Desktop.Core Namespace / TextAndGraphicsElementsOptions Class / SetDefaultLineSymbol Method
The default line symbol to set
Example
    Sets the application default line symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetDefaultLineSymbol(
       CIMLineSymbol lineSymbol
    Public Sub SetDefaultLineSymbol( _
       ByVal lineSymbol As CIMLineSymbol _
    Parameters
    lineSymbol
    Exceptions
    ExceptionDescription
    Example
    Set TextAndGraphicsElementsOptions
      await QueuedTask.Run(() =>
        //Set a default font. Use its default style
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
        //or specify an explicit style
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
        //Create symbols
        var ptSymbol2 = SymbolFactory.Instance.ConstructPointSymbol(
          ColorFactory.Instance.RedRGB, 14, SimpleMarkerStyle.Diamond);
        var lineSymbol2 = SymbolFactory.Instance.ConstructLineSymbol(
          ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.Dash);
        var polySymbol2 = SymbolFactory.Instance.ConstructPolygonSymbol(
          ColorFactory.Instance.RedRGB, SimpleFillStyle.DiagonalCross);
        var textSymbol2 = SymbolFactory.Instance.ConstructTextSymbol(
          ColorFactory.Instance.RedRGB, 12);
        //Set default point, line, poly, text graphics element symbols
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPointSymbol(ptSymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultLineSymbol(lineSymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPolygonSymbol(polySymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultTextSymbol(textSymbol2);
    Requirements
