public void SetDefaultPointSymbol( CIMPointSymbol pointSymbol )
Public Sub SetDefaultPointSymbol( _ ByVal pointSymbol As CIMPointSymbol _ )
Parameters
- pointSymbol
- The default point symbol to set
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Set a default font. Use its default style
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
//or specify an explicit style
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
//Create symbols
var ptSymbol2 = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.RedRGB, 14, SimpleMarkerStyle.Diamond);
var lineSymbol2 = SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.Dash);
var polySymbol2 = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.RedRGB, SimpleFillStyle.DiagonalCross);
var textSymbol2 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 12);
//Set default point, line, poly, text graphics element symbols
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPointSymbol(ptSymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultLineSymbol(lineSymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPolygonSymbol(polySymbol2);
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultTextSymbol(textSymbol2);
