ArcGIS.Desktop.Mapping Namespace / IStandaloneTableContainerEdit Interface / MoveStandaloneTable Method / MoveStandaloneTable(StandaloneTable,Int32) Method
A table to be moved.
The position specified by the 0-based index. If the index is invalid, the table is moved to the bottom.
    Move a table to another position within the container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    void MoveStandaloneTable(
       StandaloneTable table,
       int position
    Overloads Sub MoveStandaloneTable( _
       ByVal table As StandaloneTable, _
       ByVal position As Integer _
    Parameters
    table
    position
    Exceptions
    ExceptionDescription
    Requirements
