ArcGIS.Desktop.Mapping Namespace / ITablePane Interface / BringIntoView Method
Row index to scroll to.
Example
    BringIntoView Method (ITablePane)
    Scroll the table grid to the desired row and keep the current field.
    Syntax
    Function BringIntoView( _
       ByVal rowIndex As Integer _
    ) As Task
    Task BringIntoView(
       int rowIndex
    Parameters
    rowIndex
    Return Value
    A Task of the operation.
    Example
    Move to a particular row
        // Check if the active pane is an ITablePane
        if (FrameworkApplication.Panes.ActivePane is ITablePane tablePane)
            // move to first row
            tablePane.BringIntoView(0);
            // move to sixth row
            tablePane.BringIntoView(5);
    Requirements
