public void RemoveStandaloneTable( StandaloneTable table )
Public Sub RemoveStandaloneTable( _ ByVal table As StandaloneTable _ )
Parameters
- table
- The StandaloneTable to remove
| Exception | Description |
| System.ArgumentException | Invalid container. The StandaloneTable is not part of this container or one of it's descendants. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//get the first group layer that has at least one table
var grp_layer = map.GetLayersAsFlattenedList()
.OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
await QueuedTask.Run(() =>
//get the tables from the map container
var tables = map.GetStandaloneTablesAsFlattenedList();
//delete the first...
if (tables.Count() > 0)
map.RemoveStandaloneTable(tables.First());
//or delete all of them
map.RemoveStandaloneTables(tables);
//delete a table from a group layer
//assumes it has at least one table...
grp_layer.RemoveStandaloneTable(grp_layer.StandaloneTables.First());
