ArcGIS.Desktop.Mapping Namespace / Map Class / GetStandaloneTablesAsFlattenedList Method
Example
    GetStandaloneTablesAsFlattenedList Method (Map)
    Returns a read only flat list of StandaloneTables where nested groups are not preserved.
    Syntax
    public IReadOnlyList<StandaloneTable> GetStandaloneTablesAsFlattenedList()
    Public Function GetStandaloneTablesAsFlattenedList() As IReadOnlyList(Of StandaloneTable)
    Return Value
    A IReadOnlyList of StandaloneTables
    Example
    Find table templates belonging to a standalone table
    // retrieve editing templates associated with standalone tables in the active map.
    await QueuedTask.Run(() =>
      //Get a particular table template
      var tableTemplate = activeMap.FindStandaloneTables("Address Points").FirstOrDefault()?.GetTemplate("Residences");
      //Get all the templates of a standalone table
      var ownersTableTemplates = activeMap.FindStandaloneTables("Owners").FirstOrDefault()?.GetTemplates();
      var statisticsTableTemplates = activeMap.GetStandaloneTablesAsFlattenedList().First(l => l.Name.Equals("Trading Statistics")).GetTemplates();
    Retrieve a table from its container
      var container = MapView.Active.Map;
      //the map standalone table collection
      var table = container.GetStandaloneTablesAsFlattenedList()
                              .FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
      //or from a group layer
      var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
      var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
      //or         grp_layer.GetStandaloneTablesAsFlattenedList().First()
      //or         grp_layer.StandaloneTables.Where(...).First(), etc.
      //show the table in a table view
      //use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
      FrameworkApplication.Panes.OpenTablePane(table2);
    Remove a Standalone table
      //get the first group layer that has at least one table
      var grp_layer = map.GetLayersAsFlattenedList()
        .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
        //get the tables from the map container
        var tables = map.GetStandaloneTablesAsFlattenedList();
        //delete the first...
        if (tables.Count() > 0)
          map.RemoveStandaloneTable(tables.First());
          //or delete all of them
          map.RemoveStandaloneTables(tables);
        //delete a table from a group layer
        //assumes it has at least one table...
        grp_layer.RemoveStandaloneTable(grp_layer.StandaloneTables.First());
    Requirements
