ArcGIS.Desktop.Mapping Namespace / Map Class / MoveStandaloneTable Method / MoveStandaloneTable(StandaloneTable,CompositeLayerWithTables,Int32) Method
A table to be moved.
The layer container to move the table to.
The position specified by the 0-based index. -1 will move the table the bottom of the container. If the index is invalid, the table is moved to the bottom of the container.
Example
    Moves a StandaloneTable to a position within the specified targetLayer container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void MoveStandaloneTable(
       StandaloneTable table,
       CompositeLayerWithTables targetLayer,
       int position
    Public Overloads Sub MoveStandaloneTable( _
       ByVal table As StandaloneTable, _
       ByVal targetLayer As CompositeLayerWithTables, _
       ByVal position As Integer _
    Parameters
    table
    targetLayer
    position
    Exceptions
    ExceptionDescription
    The table is null.
    Remarks
    If targetLayer is null, the StandaloneTable is moved to the specified position within the map.
    Example
    Move a Standalone table
      //get the first group layer that has at least one table
      var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
        .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
      grp_layer.MoveStandaloneTable(grp_layer.StandaloneTables.First(), -1);
      //move the last table in the map standalone tables to a group
      //layer and place it at position 3. If 3 is invalid, the table
      //will be placed at the bottom of the target container
      //assumes the map has at least one standalone table...
      var table = map.StandaloneTables.Last();
      map.MoveStandaloneTable(table, grp_layer, 3);
      //move a table from a group layer to the map standalone tables
      //collection - assumes a table called 'Earthquakes' exists
      var table2 = grp_layer.FindStandaloneTables("Earthquakes").First();
      //move to the map container
      map.MoveStandaloneTable(table2, 0);//will be placed at the top
    Requirements
