ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / CreateTemplate Method / CreateTemplate(MapMember,String,String,Inspector,String,String[],String[]) Method
The map member the new template is to be added to.
The template name.
Optional description of the template.
An ArcGIS.Desktop.Editing.Attributes.Inspector object containing default template values.
Optional, If not provided will use the default tool for the map member type. The defaultTool can be specified using daml-id.
Optional. A set of tags.
Optional list of tools to not allow for this template. Tool filters can be specified using daml-id.
Example
    Creates a new template using the specified definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function CreateTemplate( _
       ByVal mapMember As MapMember, _
       ByVal templateName As String, _
       Optional ByVal description As String, _
       Optional ByVal inspector As Inspector, _
       Optional ByVal defaultTool As String, _
       Optional ByVal tags() As String, _
       Optional ByVal toolFilter() As String _
    ) As EditingTemplate
    Parameters
    mapMember
    templateName
    The template name.
    description
    inspector
    defaultTool
    tags
    toolFilter
    Return Value
    The newly created template. Null if it cannot be created.
    Exceptions
    ExceptionDescription
    The Template name cannot be empty. And the template name must be unique.
    Example
    Create New Template using layer.CreateTemplate
    await QueuedTask.Run(() =>
        var newFieldValues = new object[] { "Value1", 123, DateTime.Now };
        // Creates a new editing template for the specified feature layer with the provided field values.
        var insp = new Inspector();
        insp.LoadSchema(featureLayer);
        insp["Field1"] = newFieldValues[0];
        insp["Field2"] = newFieldValues[1];
        insp["Field3"] = newFieldValues[2];
        var tags = new[] { "Polygon", "tag1", "tag2" };
        // set defaultTool using a daml-id
        string defaultTool = "esri_editing_SketchCirclePolygonTool";
        // tool filter is the tools to filter OUT
        var toolFilter = new[] { "esri_editing_SketchTracePolygonTool" };
        // create a new template
        var newTemplate = featureLayer.CreateTemplate("My new template", "description", insp, defaultTool, tags, toolFilter);
    Create New Table Template using table.CreateTemplate
    // Creates new table templates for the specified standalone table.
      var table = activeMap.GetStandaloneTablesAsFlattenedList().FirstOrDefault();
      var tableTemplate = table.GetTemplate("Template1");
      var definition = tableTemplate.GetDefinition();
      definition.Description = "New definition";
      definition.Name = "New name";
      //Create new table template using this definition
      table.CreateTemplate(definition);
      //You can also create a new table template using this extension method. You can use this method the same way you use the layer.CreateTemplate method.
      table.CreateTemplate("New template name", "Template description", tags: ["tag 1", "tag 2"]);
    Create Annotation Template
    // Creates a new annotation template for the specified annotation layer.
        Inspector insp = null;
        // get the anno feature class
        var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass;
        // get the feature class CIM definition which contains the labels, symbols
        var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition;
        var labels = cimDefinition.GetLabelClassCollection();
        var symbols = cimDefinition.GetSymbolCollection();
        // make sure there are labels, symbols
        if (labels.Count == 0 || symbols.Count == 0)
          return;
        // find the label class required
        //   typically you would use a subtype name or some other characteristic
        // in this case lets just use the first one
        var label = labels[0];
        // each label has a textSymbol
        // the symbolName *should* be the symbolID to be used
        var symbolName = label.TextSymbol.SymbolName;
        int symbolID = -1;
        if (!int.TryParse(symbolName, out symbolID))
          // int.TryParse fails - attempt to find the symbolName in the symbol collection
          foreach (var symbol in symbols)
            if (symbol.Name == symbolName)
              symbolID = symbol.ID;
              break;
        // no symbol?
        if (symbolID == -1)
          return;
        // load the schema
        insp.LoadSchema(annotationLayer);
        // ok to assign these fields using the inspector[fieldName] methodology
        //   these fields are guaranteed to exist in the annotation schema
        insp["AnnotationClassID"] = label.ID;
        insp["SymbolID"] = symbolID;
        // set up some additional annotation properties
        AnnotationProperties annoProperties = insp.GetAnnotationProperties();
        annoProperties.FontSize = 36;
        annoProperties.TextString = "My Annotation feature";
        annoProperties.VerticalAlignment = VerticalAlignment.Top;
        annoProperties.HorizontalAlignment = HorizontalAlignment.Justify;
        insp.SetAnnotationProperties(annoProperties);
        var tags = new[] { "Annotation", "tag1", "tag2" };
        // use daml-id rather than guid
        string defaultTool = "esri_editing_SketchStraightAnnoTool";
        var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" };
        var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter);
    Requirements
