ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / RemoveTemplate Method / RemoveTemplate(MapMember,EditingTemplate) Method
The map member containing the template.
The template to be removed.
Example
    Removes the specified template.
    Syntax
    Public Overloads Shared Sub RemoveTemplate( _
       ByVal mapMember As MapMember, _
       ByVal template As EditingTemplate _
    public static void RemoveTemplate(
       MapMember mapMember,
       EditingTemplate template
    Parameters
    mapMember
    template
    Example
    Remove a table template
    // Removes predefined editing templates associated with the specified standalone table.
    await QueuedTask.Run(() =>
      var tableTemplate = table.GetTemplate("Template1");
      //Removing a table template
      table.RemoveTemplate(tableTemplate);
      //Removing a template by name
      table.RemoveTemplate("Template2");
    Requirements
