ArcGIS.Core.Data.UtilityNetwork Namespace / TraverseAssociationsDescription Class / TraverseAssociationsDescription Constructor / TraverseAssociationsDescription Constructor(TraversalDirection,Int32)
Specifies the direction to perform the association traversal.
Specifies the maximum number of hops through the association graph to traverse in a specified traversalDirection
Example
    Initializes a new instance of TraverseAssociationsDescription with a full traversal in a specified TraversalDirection with a user-defined depth limit.
    Syntax
    Public Function New( _
       ByVal traversalDirection As TraversalDirection, _
       ByVal maximumDepth As Integer _
    public TraverseAssociationsDescription(
       TraversalDirection traversalDirection,
       int maximumDepth
    Parameters
    traversalDirection
    maximumDepth
    Example
    Get traverse associations result from downward traversal
      // This routine demonstrates how to get the associations involved in a downward traversal from a set of starting elements
      static void GetTraverseAssociationsResultFromDownwardTraversal(UtilityNetwork utilityNetwork, IReadOnlyList<Element> startingElements)
        // Set downward traversal with maximum depth
        TraverseAssociationsDescription traverseAssociationsDescription =
          new TraverseAssociationsDescription(TraversalDirection.Descending);
        // Get traverse associations result from the staring element up to maximum depth
        TraverseAssociationsResult traverseAssociationsResult =
          utilityNetwork.TraverseAssociations(startingElements, traverseAssociationsDescription);
        // Get associations participated in traversal
        IReadOnlyList<Association> associations = traverseAssociationsResult.Associations;
    Get traverse associations result from upward traversal with depth limit
      // This routine demonstrates how to get the associations involved in an upward traversal from a set of starting elements, up to a specified depth limit
      static void GetTraverseAssociationsResultFromUpwardTraversalWithDepthLimit(UtilityNetwork utilityNetwork, IReadOnlyList<Element> startingElements)
        // List of fields whose values will be fetched as name-values pairs during association traversal operation
        List<string> additionalFieldsToFetch =
          new List<string> { "ObjectId", "AssetName", "AssetGroup", "AssetType" };
        // Set downward traversal with maximum depth level of 3
          new TraverseAssociationsDescription(TraversalDirection.Ascending, 3)
            AdditionalFields = additionalFieldsToFetch
        // Get traverse associations result from the staring element up to depth level 3
        // List of associations participated in traversal
        // KeyValue mapping between involved elements and their field name-values
        IReadOnlyDictionary<Element, IReadOnlyList<FieldValue>> associationElementValuePairs =
          traverseAssociationsResult.AdditionalFieldValues;
        foreach (KeyValuePair<Element, IReadOnlyList<FieldValue>> keyValuePair in associationElementValuePairs)
          // Element
          Element element = keyValuePair.Key;
          // List of field names and their values
          IReadOnlyList<FieldValue> elementFieldValues = keyValuePair.Value;
    Requirements
