ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / HandleMouseDownAsync Method
A LayoutViewMouseButtonEventArgs that contains the event data.
    HandleMouseDownAsync Method (LayoutTool)
    Occurs when the OnToolMouseDown event is handled.
    Syntax
    protected virtual Task HandleMouseDownAsync(
       LayoutViewMouseButtonEventArgs args
    Protected Overridable Function HandleMouseDownAsync( _
       ByVal args As LayoutViewMouseButtonEventArgs _
    ) As Task
    Parameters
    args
    Return Value
    A Task that represents a mouse down event.
    Remarks
    This method is intended to perform asynchronous operations associated with a mouse down event. It will be called if you override the OnToolMouseDown virtual method and set the handled property on the LayoutViewMouseButtonEventArgs to true.
    Requirements
