ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / OnToolMouseDown Method
A LayoutViewMouseButtonEventArgs that contains the event data.
    OnToolMouseDown Method (LayoutTool)
    Occurs when a mouse button is pressed on the view.
    Syntax
    protected virtual void OnToolMouseDown(
       LayoutViewMouseButtonEventArgs args
    Protected Overridable Sub OnToolMouseDown( _
       ByVal args As LayoutViewMouseButtonEventArgs _
    Parameters
    args
    Remarks
    This method is intended to perform synchronous operations associated with a mouse down event. To perform any asynchronous operations set the handled property on the LayoutViewMouseButtonEventArgs to true and override the HandleMouseDownAsync virtual method.
    Requirements
