ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / HandleMouseUpAsync Method
A LayoutViewMouseButtonEventArgs that contains the event data.
    HandleMouseUpAsync Method (LayoutTool)
    Occurs when the OnToolMouseUp event is handled.
    Syntax
    protected virtual Task HandleMouseUpAsync(
       LayoutViewMouseButtonEventArgs args
    Protected Overridable Function HandleMouseUpAsync( _
       ByVal args As LayoutViewMouseButtonEventArgs _
    ) As Task
    Parameters
    args
    Return Value
    A Task that represents a mouse up event.
    Remarks
    This method is intended to perform asynchronous operations associated with a mouse up event. It will be called if you override the OnToolMouseUp virtual method and set the handled property on the LayoutViewMouseButtonEventArgs to true.
    Requirements
