ArcGIS.Desktop.Layouts Namespace / LayoutTool Class / OnToolMouseUp Method
A LayoutViewMouseButtonEventArgs that contains the event data.
    OnToolMouseUp Method (LayoutTool)
    Occurs when a mouse button is released on the view.
    Syntax
    protected virtual void OnToolMouseUp(
       LayoutViewMouseButtonEventArgs args
    Protected Overridable Sub OnToolMouseUp( _
       ByVal args As LayoutViewMouseButtonEventArgs _
    Parameters
    args
    Remarks
    This method is intended to perform synchronous operations associated with a mouse up event. To perform any asynchronous operations set the handled property on the LayoutViewMouseButtonEventArgs to true and override the HandleMouseUpAsync virtual method.
    Requirements
