ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / TraceConfiguration Class / TraceConfiguration Constructor
Example
    Creates a new instance of the TraceConfiguration class.
    Syntax
    Public Function New()
    public TraceConfiguration()
    Example
    Create a Trace Argument
      // This routine creates a TraceArgument object and assigns a TraceConfiguration to it
      static void CreateTraceArgument()
        IReadOnlyList<Element> startingPointList = new List<Element>();
        // Code to fill in list of starting points goes here...
        TraceArgument traceArgument = new TraceArgument(startingPointList);
        TraceConfiguration traceConfiguration = new TraceConfiguration();
        // Code to fill in trace configuration goes here...
        traceArgument.Configuration = traceConfiguration;
    Trace a utility network with the digitized direction
      // This routine demonstrates how to perform a trace using the digitized direction of features
      static void TraceWithDigitizedDirection(UtilityNetwork utilityNetwork, Element startElement)
        using TraceManager traceManager = utilityNetwork.GetTraceManager();
        // Trace configuration with digitized direction
          IncludeIsolatedFeatures = true,
          IncludeBarriersWithResults = true,
          UseDigitizedDirection = true
        // Trace argument
        List<Element> startElements = new List<Element> { startElement };
        TraceArgument traceArgument = new TraceArgument(startElements);
        // Results
        DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
        IReadOnlyList<Result> traceResults = downstreamTracer.Trace(traceArgument);
        foreach (Result traceResult in traceResults)
          // Iterate trace results
    Requirements
