ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GeodesicLength Method / GeodesicLength(Geometry,LinearUnit) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
The units of the output. If null, then the output is in meters
Example
    Gets the geodesic length of the input geometry.
    Syntax
    Overloads Function GeodesicLength( _
       ByVal geometry As Geometry, _
       ByVal outputUnit As LinearUnit _
    ) As Double
    Parameters
    geometry
    outputUnit
    Return Value
    The calculated geodesic length in outputUnit. If outputUnit is null, then the length is in meters.
    If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or geometry's spatial reference is null.
    The method is not implemented for GeometryBag or Multipatch.
    Spatial reference of geometryis an image coordinate system.
    Remarks
    Geodesic length is calculated by using only the vertices of the geometry and defining the segments between the points as geodesic segments independent of the actual shape of the geometry. A geodesic segment is the shortest path between two points on an ellipsoid. For example, if you have a closed polyline with only two vertices that represents the equator, the length returned will be zero.
    Example
    Determine geodesic length of a line
      polyline = PolylineBuilderEx.CreatePolyline(
          MapPointBuilderEx.CreateMapPoint(-10018754.1713946, 10018754.1713946),
      MapPointBuilderEx.CreateMapPoint(10018754.1713946, 10018754.1713946)
      ], SpatialReferences.WebMercator);
      var length = GeometryEngine.Instance.GeodesicLength(polyline);
      // length is approx 5243784.5551844323 in meters
      length = GeometryEngine.Instance.GeodesicLength(polyline, LinearUnit.Miles);
      // length is approx 3258.33666089067 in miles
      var polyline2 = GeometryEngine.Instance.Project(polyline, SpatialReferences.WGS84);
      length = GeometryEngine.Instance.GeodesicLength(polyline2);
      // length is approx 5243784.55518443 in meters after projecting
    Requirements
