ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / CentralAngle Property
Example
    CentralAngle Property (EllipticArcBuilderEx)
    Gets or sets the central angle in radians.
    Syntax
    public double CentralAngle {get; set;}
    Public Property CentralAngle As Double
    Property Value
    A double representing the central angle.
    Exceptions
    ExceptionDescription
    The CentralAngle is NaN.
    Remarks
    The central angle is the angular measure between the StartAngle and the EndAngle. It is measured in radians and is always between -2 * PI and 2 * PI. If the elliptic arc is oriented in a counterclockwise direction, then the central angle > 0. Otherwise, the central angle < 0. Changing the central angle may also change the end point, end angle, and orientation.
    Example
    Elliptic Arc Builder Properties
      // retrieve the curve's properties
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(ellipticArcSegment);
      MapPoint startPt = builder.StartPoint;
      MapPoint endPt = builder.EndPoint;
      Coordinate2D centerPt = builder.CenterPoint;
      bool isCircular = builder.IsCircular;
      bool isMinor = builder.IsMinor;
      double startAngle = builder.StartAngle;
      double endAngle = builder.EndAngle;
      double centralAngle = builder.CentralAngle;
      double rotationAngle = builder.RotationAngle;
      ArcOrientation orientation = builder.Orientation;
    Requirements
