ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GeodesicBuffer Method / GeodesicBuffer(Geometry,Double,LinearUnit) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
The distance to buffer the geometry.
The unit of the buffer distance. If null, then the buffer distance is in meters.
    Creates a buffer polygon at the specified geodesic distance around the given geometry.
    Syntax
    Public Overloads Function GeodesicBuffer( _
       ByVal geometry As Geometry, _
       ByVal distance As Double, _
       ByVal distanceUnit As LinearUnit _
    ) As Geometry
    Parameters
    geometry
    distance
    distanceUnit
    Return Value
    A geometry representing the buffered area. If the input geometry is empty, then an empty polygon is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or empty. Or geometry's spatial reference is null.
    The method is not implemented for GeometryBag.
    Geometry has no spatial reference.
    The buffer distance must be a valid floating point number.
    Spatial reference of geometryis an image coordinate system.
    Remarks
    Geodesic distance is the shortest distance between two points on the surface of the Earth.
    If the buffer distance is zero and the input geometry is a polygon or an envelope, then a polygon created from the input geometry is returned.
    If the distance is less than or equal to zero and the input geometry is not a polygon or an envelope, then an empty polygon is returned.
    Requirements
