OpenTablePane(PaneCollection,MapMember,TableViewMode) Method
Opens a table pane for a MapMember. If a table pane is already open it will be activated.
You must be on the UI thread to call this function.
Retrieve a table from its container
var container = MapView.Active.Map;
//the map standalone table collection
var table = container.GetStandaloneTablesAsFlattenedList()
.FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
//or from a group layer
var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
//or grp_layer.GetStandaloneTablesAsFlattenedList().First()
//or grp_layer.StandaloneTables.Where(...).First(), etc.
//show the table in a table view
//use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
FrameworkApplication.Panes.OpenTablePane(table2);
Display Table pane for Map Member
mapMember = MapView.Active.Map.GetLayersAsFlattenedList().OfType<MapMember>().FirstOrDefault();
//Gets or creates the CIMMapTableView for a MapMember.
var mapTableView = FrameworkApplication.Panes.GetMapTableView(mapMember);
//Configure the table view
mapTableView.DisplaySubtypeDomainDescriptions = false;
mapTableView.SelectionMode = false;
mapTableView.ShowOnlyContingentValueFields = true;
mapTableView.HighlightInvalidContingentValueFields = true;
//Open the table pane using the configured tableView. If a table pane is already open it will be activated.
//You must be on the UI thread to call this function.
var tablePane = FrameworkApplication.Panes.OpenTablePane(mapTableView);
