HasSymbolLayerDrawingAdded Method (GroupLayer)
Determine whether the group layer has Symbol Layer Drawing
added. This method must be called on the MCT. Use QueuedTask.Run.
Syntax
Return Value
Returns a tuple (addedOnLayer, addedOnParent). addedOnLayer will be True if the group layer has SLD added.
addedOnParent will be true if the group layer is participating in SLD
controlled by a parent group layer with SLD added.
Exceptions
Example
Determine if a layer has SLD added
//SLD can be added to feature layers and group layers
//For a group layer, SLD controls all child feature layers
//that are participating in the SLD
//var featLayer = ...;//retrieve the feature layer
//var groupLayer = ...;//retrieve the group layer
//Check if the layer has SLD added -returns a tuple
var tuple = await QueuedTask.Run(() => featureLayer.HasSymbolLayerDrawingAdded());
if (tuple.addedOnLayer)
//SLD is added on the layer
else if (tuple.addedOnParent)
//SLD is added on the parent (group layer) -
//check parent...this can be recursive
var parentLayer = await GetParentLayerWithSLDAsync(featureLayer.Parent as GroupLayer);
//Recursively get the parent with SLD
Task<GroupLayer> GetParentLayerWithSLDAsync(GroupLayer groupLayer) =>
while (groupLayer != null)
var sld_added = groupLayer.HasSymbolLayerDrawingAdded();
if (sld_added.addedOnLayer)
return groupLayer;
if (!sld_added.addedOnParent)
break;
groupLayer = groupLayer.Parent as GroupLayer;
return null;
Enable/Disable SLD
//A layer may have SLD added but is not using it
//HasSymbolLayerDrawingAdded returns a tuple - to check
//the layer has SLD (not its parent) check addedOnLayer
if (featureLayer.HasSymbolLayerDrawingAdded().addedOnLayer)
//the layer has SLD but is the layer currently using it?
//GetUseSymbolLayerDrawing returns a tuple - useOnLayer for
//the layer (and useOnParent for the parent layer)
if (!featureLayer.GetUseSymbolLayerDrawing().useOnLayer)
//enable it
featureLayer.SetUseSymbolLayerDrawing(true);
//Enable/Disable SLD on a layer parent
if (await QueuedTask.Run(() => featureLayer.HasSymbolLayerDrawingAdded().addedOnParent))
var parent = await GetParentLayerWithSLDAsync(featureLayer.Parent as GroupLayer);
if (parent != null)
if (parent.GetUseSymbolLayerDrawing().useOnLayer)
parent.SetUseSymbolLayerDrawing(true);
return groupLayer;
break;
return null;
Requirements
