ArcGIS.Core.CIM Namespace / CIMEditingTemplate Class / DefaultToolGUID Property
Example
    Gets or sets the default tool GUID.
    Syntax
    Public Property DefaultToolGUID As String
    public string DefaultToolGUID {get; set;}
    Example
    Change Default Edit tool for a template
    await QueuedTask.Run(() =>
            var templateName = "Distribution"; // name of the template to update
            var toolDamlPlugInID = "esri_editing_SketchTwoPointLineTool"; // DAML ID of the tool to set as default
            var toolContentGUID = "e2096d13-b437-4bc1-94ea-4494c3260f72"; // Example GUID, replace with actual GUID from DAML
        // retrieve the edit template form the layer by name
            var template = featureLayer?.GetTemplate(templateName) as EditingTemplate;
            // get the definition of the layer
            var layerDef = featureLayer?.GetDefinition() as CIMFeatureLayer;
            if (template == null || layerDef == null)
              return;
            if (template.DefaultToolID != toolDamlPlugInID)
              bool updateLayerDef = false;
              if (layerDef.AutoGenerateFeatureTemplates)
                layerDef.AutoGenerateFeatureTemplates = false;
                updateLayerDef = true;
              // retrieve the CIM edit template definition
              var templateDef = template.GetDefinition();
              // assign the GUID from the tool DAML definition, for example
              // <tool id="TestConstructionTool_SampleSDKTool" categoryRefID="esri_editing_construction_polyline" ….>
              //   <tooltip heading="">Tooltip text<disabledText /></tooltip>
              //   <content guid="e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" />
              // </tool>
              // then the toolContentGUID would be "e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea"
              //templateDef.ToolProgID = toolContentGUID;
              templateDef.DefaultToolGUID = toolContentGUID;
              // set the definition back to
              template.SetDefinition(templateDef);
              // update the layer definition too
              if (updateLayerDef)
                featureLayer.SetDefinition(layerDef);
    Requirements
