Public Property ServiceSynchronizationType As ServiceSynchronizationType
public ServiceSynchronizationType ServiceSynchronizationType {get; set;}
// Must be called within QueuedTask.Run
void GetVersionConflictsInfoInUpdateDeleteType(
ServiceConnectionProperties featureServiceConnectionProperties,
string featureClassName)
// To illustrate the conflict between versions,
// the feature is updated in the child version and deleted in the parent version.
long featureObjectIDForEdit = Int64.MinValue;
// Get branch versioned service
using (Geodatabase fsGeodatabase = new Geodatabase(featureServiceConnectionProperties))
using (VersionManager versionManager = fsGeodatabase.GetVersionManager())
using (Version defaultVersion = versionManager.GetDefaultVersion())
using (Geodatabase defaultGeodatabase = defaultVersion.Connect())
using (FeatureClass defaultFeatureClass = defaultGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (FeatureClassDefinition defaultFeatureClassDefinition = defaultFeatureClass.GetDefinition())
// Create a feature in the default version to edit in a branch
defaultGeodatabase.ApplyEdits(() =>
using (RowBuffer rowBuffer = defaultFeatureClass.CreateRowBuffer())
rowBuffer["NAME"] = "Loblolly Pine";
rowBuffer["TREEAGE"] = 1;
rowBuffer[defaultFeatureClassDefinition.GetShapeField()] = new MapPointBuilderEx(new Coordinate2D(1, 1),
SpatialReferenceBuilder.CreateSpatialReference(4152, 0)).ToGeometry();
using (Feature feature = defaultFeatureClass.CreateRow(rowBuffer))
featureObjectIDForEdit = feature.GetObjectID();
// Add newly created feature in the filter
QueryFilter queryFilter = new QueryFilter { ObjectIDs = new List<long> { featureObjectIDForEdit } };
// Create a branch version
VersionDescription versionDescription = new VersionDescription("UpdateDeleteConflictType",
"Update-Delete version conflict type", VersionAccessType.Public);
// Edit the feature in the branch
using (Version editVersion = versionManager.CreateVersion(versionDescription))
using (Geodatabase branchGeodatabase = editVersion.Connect())
using (FeatureClass featureClass = branchGeodatabase.OpenDataset<FeatureClass>(featureClassName))
using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
branchGeodatabase.ApplyEdits(() =>
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
row["TREEAGE"] = 100;
row["NAME"] = $"{row["Name"]}_EditInBranch";
row.Store();
// Delete the feature from the default version
defaultFeatureClass.DeleteRows(queryFilter);
// Reconcile options
ReconcileOptions reconcileOptions = new ReconcileOptions(defaultVersion)
ConflictResolutionType = ConflictResolutionType.FavorEditVersion,
ConflictDetectionType = ConflictDetectionType.ByRow,
ConflictResolutionMethod = ConflictResolutionMethod.Continue
// Reconcile with default
ReconcileResult reconcileResult = editVersion.Reconcile(reconcileOptions);
// Check for conflicts
bool hasConflictsReconcileResults = reconcileResult.HasConflicts;
bool hasConflictsAfterReconcile = editVersion.HasConflicts();
// Fetch conflicts
IReadOnlyList<Conflict> conflictsAfterReconcile = editVersion.GetConflicts();
// Iterate conflicts
foreach (Conflict conflict in conflictsAfterReconcile)
// Object ID of row where conflict occurs
long objectId = conflict.ObjectID;
ConflictType conflictType = conflict.ConflictType;
IReadOnlyList<FieldValue> ancestorVersionValues = conflict.AncestorVersionValues;
object nameAncestor = ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeAncestor =
ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> childVersionValues = conflict.ChildVersionValues;
object nameChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
object treeAgeChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
IReadOnlyList<FieldValue> parentVersionValues = conflict.ParentVersionValues;
IReadOnlyList<Field> originalFields = defaultFeatureClassDefinition.GetFields();
string datasetName = conflict.DatasetName;
void ReconcileAndPost(Geodatabase geodatabase)
// Get a reference to our version and our parent
if (geodatabase.IsVersioningSupported())
using (VersionManager versionManager = geodatabase.GetVersionManager())
using (Version currentVersion = versionManager.GetCurrentVersion())
using (Version parentVersion = currentVersion.GetParent())
// Create a ReconcileOptions object
ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
if (!reconcileResult.HasConflicts)
//No conflicts, perform the post
PostOptions postOptions = new PostOptions(parentVersion);
//var postOptions = new PostOptions(); for default version
postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
// Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
// currentVersion.Post(postOptions);
currentVersion.Reconcile(reconcileOptions, postOptions);
void ReconcileAndPost2(Geodatabase geodatabase)
// Reconcile
ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
if (reconcileResult.HasConflicts)
//TODO resolve conflicts
